		| Author | Message |
		| Steve Stolen Guest
				| 18F452 Data EEPROM Writes Don't Work (write_eeprom(addr,data |
				|  Posted: Sat Nov 09, 2002 4:23 pm |   |
				| During my conversion efforts to upgrade to the 18F452 from the 16F877 I ran into a write_eeprom(), read_eeprom() problem. THe program previously worked on the 16F877 so it is a port of good code. I'm using PCWH v3.123 and the PICALLW 0.13d version of the programmer software for my PICALL programmer. None of my writes to the data EEPROM appear to work, at least they don't get read back. I looked into the Configuration bits, CONFIGURATION Register 6 High, WRTD (bit 7) using the config bit view option on PICALLW and I see the bit (WRTD) off when I do nothing special with the fuses (ie default). The WRTD bit, according to the datasheet (pg 200) shows WRTD needs to be on. So, I looked at the valid fuses CCS has in the latest GUI and find that there are options WRTD and NOWRTD. Well, these behave backwards from what they are supposed to set. #FUSE ....,WRTD sets the bit to 0 instead of 1 and the NOWRTD reverses that, sets to 1 instead of 0. In both cases, the write_eeprom() doesn't work. Program goes through the motions with no objections, but the reads come back as the erased state of 0xFF.
 Any ideas? Workarounds? Is this a known problem?
 ___________________________
 Original Post ID: 8714
		| Steve Stolen Guest
				| Re: 18F452 Data EEPROM Writes Don't Work (write_eeprom(addr, |
				|  Posted: Sat Nov 09, 2002 7:11 pm |   |
				| :=During my conversion efforts to upgrade to the 18F452 from the 16F877 I ran into a write_eeprom(), read_eeprom() problem. THe program previously worked on the 16F877 so it is a port of good code. I'm using PCWH v3.123 and the PICALLW 0.13d version of the programmer software for my PICALL programmer. None of my writes to the data EEPROM appear to work, at least they don't get read back. I looked into the Configuration bits, CONFIGURATION Register 6 High, WRTD (bit 7) using the config bit view option on PICALLW and I see the bit (WRTD) off when I do nothing special with the fuses (ie default). The WRTD bit, according to the datasheet (pg 200) shows WRTD needs to be on. So, I looked at the valid fuses CCS has in the latest GUI and find that there are options WRTD and NOWRTD. Well, these behave backwards from what they are supposed to set. #FUSE ....,WRTD sets the bit to 0 instead of 1 and the NOWRTD reverses that, sets to 1 instead of 0. In both cases, the write_eeprom() doesn't work. Program goes through the motions with no objections, but the reads come back as the erased state of 0xFF. :=
 :=Any ideas? Workarounds? Is this a known problem?
 I thought I would back up to the last known fairly stable version (I guessed at 3.110 because CCS has that version as the alternate download). I recompiled, checked the fuses with PICALLW, found a lot of fuses were set at FFFF in the config words, changed Conf Word 6Hi to 0x80 to turn on the WRTD flag, popped the PIC into the target hardware, and the write/read_eeprom() functions now appear to work. So, now I gotta get together the audit trail and send in a bug report. The newer fixes/features I also need, but can cope with this for now.
 Original Post ID: 8716
		| SL1978 Guest
				|  Posted: Mon Nov 11, 2002 2:45 am |   |
 There are some bug there but u can my routine, it work
 #define EEADR 0xFA9
 #define EEDATA 0xFA8
 #define EECON1 0xFA6
 #define RD 0
 #define WR 1
 #define WREN 2
 #define WRERR 3
 #define FREE 4
 #define CFGS 6
 #define EEPGD 7
 #define EECON2 0xFA7
 #define PIR2 0xFA1
 #define EEIF 4
 void write_int_eeprom(int address, int data)
 bit_clear(*EECON1, CFGS);	//access prog or data memory
 bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
 (int)*EEADR = address; // Load our address
 (int)*EEDATA = data; // Load our data
 bit_clear(*EECON1, EEPGD); // Point to data memory
 bit_set(*EECON1, WREN); // Enable writes
 // Microchip recommends disabling ints here
 disable_interrupts(GLOBAL);  //note must modify to wait for int complete
 (int)*EECON2 = 0x55; // Write 0x55
 (int)*EECON2 = 0xAA; // Write 0xAA
 bit_set(*EECON1, WR); // Set WR to begin write
 // Ok to turn back on ints
 // Wait for the write to complete
 while (!bit_test(*PIR2, EEIF));
 bit_clear(*EECON1, WREN); // disable writes
 /*-------------------- Read Int EEPROM subroutine ---------------------------
 int read_int_eeprom(int address)
 bit_set(*EECON1, RD); // EEPROM Read
 return(*EEDATA); // Return with our value
 Original Post ID: 8744
 | You cannot post new topics in this forum You cannot reply to topics in this forum
