cer
| 2 LM35 Temperature sensors, 1 motor, 2 switches and 2 relays |
Posted: Wed Jan 11, 2012 7:39 pm |
I have some problems with this ( http://imageshack.us/f/717/schematicsq.png/ )circuit and code. I'll be thankful if you help.
When I power the circuit:
1- Interrupts do not work (I think it is because int_rb does not work for RB1 pin but what about the int_ext?)
2- I do not see stable voltages on LM35 pins; sometimes they give 250mV and after 2,5V, 0V, 10mV etc. and sometimes they get stable(they are on pin headers on schematics).
3- Relays get on and off randomly.
4- When it gets in the while loop to read adc_channel(0), it does not go back to read adc_channel(1). I mean it does not get out of the while loop of channel(1) Here is the adc code for that loop:
set_adc_channel(1); //DIŞ SENSÖR OKUNUYOR |Outside LM35 Reading
delay_us(20);
bilgi_dis=read_adc(); //data_outside
while (bilgi_dis>79)
output_high(pin_a7);
menfez_kapat();
while(bilgi_dis<79) //data_outside
set_adc_channel(0); //İÇ SENSÖR OKUNUYOR |Inside LM35 Reading
delay_us(20);
bilgi_ic=read_adc(); //data_inside
if (bilgi_ic>79)
fan1_calis();
fan2_calis();
output_high(pin_a6);
menfez_ac();
else if(bilgi_ic<79 && bilgi_ic>62)
fan1_calis();
fan2_kapat();
menfez_ac();
else if(bilgi_ic<62)
fan1_kapat();
fan2_kapat();
menfez_ac();
5- LEDs on RA6 and RA7 pins do not turn off when they do not match the criteria (I may not have wrote the code for that, I am not sure).
6- When I write set_tris_x(), #use fast_io(x) and define the input/output pins, one of the LM35s give voltages in reverse (the more hot it gets, the less voltage it gives).
Here is the full code:
#include "16F88.h"
#device ADC=10
#fuses INTRC_IO,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOWRT,NODEBUG,NOCPD
#use delay (clock=8000000)
/*#use fast_io(a)
#use fast_io(b)*/
#int_ext
void ust_bumper() //Motor stops if bumper_switch_1 go high
output_low(pin_a4);
output_low(pin_a3);
output_low(pin_a2);
output_b(0x00);
#int_RB
void alt_bumper() //Motor stops if bumper_switch_2 go high
if(input(pin_b1))
output_low(pin_a4);
output_low(pin_a3);
output_low(pin_a2);
output_b(0x00);
unsigned int32 bilgi_ic, bilgi_dis; //data_inside, data_outside
void menfez_ac() //run motor forward
output_high(pin_b6);
output_high(pin_b5);
output_low(pin_b4);
void menfez_kapat() //run motor backwards
output_low(pin_b5);
output_high(pin_b4);
void fan1_calis() //relay1_on
output_high(pin_b2);
void fan2_calis() //relay2_on
output_high(pin_b3);
void fan1_kapat() //relay1_off
output_low(pin_b2);
void fan2_kapat() //relay2_off
output_low(pin_b3);
setup_oscillator(OSC_8MHZ);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_CCP1(CCP_OFF);
/*set_tris_a(0b00000011);
set_tris_b(0b00000011);*/
setup_adc(adc_clock_div_32);
setup_adc_ports(sAN0|sAN1);
ext_int_edge(L_TO_H);
enable_interrupts(INT_RB);
enable_interrupts(INT_EXT);
setup_adc_ports(sAN0|sAN1|VSS_VDD);
output_high(pin_b7); //LED to see if PIC is running
output_low(pin_b7);
delay_us(20);
menfez_kapat();
delay_us(20);
if (bilgi_ic>79)
fan1_calis();
fan2_calis();
menfez_ac();
fan1_calis();
fan2_kapat();
menfez_ac();
fan1_kapat();
fan2_kapat();
menfez_ac();
Thanks in advance, any help will be appreciated!
cer
Posted: Wed Jan 11, 2012 8:02 pm |
btw it does not execute this code as i understood but i might be wrong. I thought so because it does not power the LED by output_high(pin_a7);
| Code: | set_adc_channel(1); //DIŞ SENSÖR OKUNUYOR |Outside LM35 Reading
delay_us(20);
menfez_kapat();
cer
Posted: Thu Jan 12, 2012 7:13 am |
| It reads only channel(0) and does not react on what happened on channel(1). How can i break the channel(0) loop? |
Posted: Thu Jan 12, 2012 8:05 am |
i could be wrong , but i was under the impression that you have to READ port B to clear the interrupt not write to it.
care to post the SCHEMATIC of this device ??
that would help ME to figure out what could be wrong.
cer
Posted: Thu Jan 12, 2012 8:10 am |
| asmboy schematics link is under the post. How do i clear the interrupt without writing in it? Is the poblem here: output_b(0x00);? |
Posted: Thu Jan 12, 2012 8:18 am |
try
byte junk;
junk=input_b();
ALSO
i suggest that the LM35's SHOULD have a weak pull DOWN resistor to ground
say 10k ohms -with a .1UF metal film CAPACITOR in paraLLEL
cer
Posted: Thu Jan 12, 2012 8:20 am |
| asmboy wrote: | try
byte junk;
junk=input_b(); |
Should this be in the interrupt function or a global one? |
Joined: 01 Jul 2010 Posts: 9642 Location: Greensville,Ontario
Posted: Thu Jan 12, 2012 8:26 am |
some comments..
INT_RB().. only gets triggered when there's a change on portb.7,.6,.5, or .4 ( the high nibble) and you MUST read the port to clear it.
You only read the inside LM35 IF the outside LM35 is < 79 bits.
You are using set_tris....().. Not necessary, the compiler will do it all for you.
Same comment about 'fast_io'....let the compiler do this, it'll keep the LM35s cool !!
LM35s. Need a stable power source. Put a 10mfd cap at their Vin. Also put a small cap( .01, .1) on the output to the ADC pin. If you read the datasheet you'll see they will oscillate unless properly connected.
Relays. Be sure to use diodes on the coils! What is between the PIC and the relays? Transistors, IC, ?
What is the power supply? It should be at least 2 AMPS depending on the relays you use. At least 2 X the maximum draw for ALL relays being on at the same time.
Be sure to use good bypass/filtering caps near the PIC. Noise from the relays could reset of corrupt the PICs pins.
Be sure to use say 500r to 1k resistors for the LEDs. |
cer
Posted: Thu Jan 12, 2012 8:41 am |
@temtronics
How can I read the port to clear it?
Yes, I wrote it intentionally, thanks anyway.
I removed set_tris and fast_io on behalf of your comment.
Schematics link is on the first post. I am using 1N4007. There are BC547 between PIC and relays as you can see on schematics.
OK, I'll add filtering caps.
I do not use resistors for the LEDs, it works anyway. What kind of a problem can occur if I do not use resistors for the LEDs?
Thank you very much for your comments and waiting for further comments if it is OK for you  |
Posted: Thu Jan 12, 2012 8:57 am |
You must use current limiting resistors otherwise you WILL stress the PIC and eventually destroy it. While it might seem to work, over time, it will do 'weird' stuff, not run right even though the code is correct.
to read the port, please press F11 while your project is open. this will bring up the 'onscreen' help files of the compiler( mine is always open) giving you access to almost everything you need to know about CCS C and how to use it.The FAQ section should have detials about reading ports and of course look at some of the examples in the 'examples' folder to see how CCS does some coding.
hope this helps |
cer
Posted: Thu Jan 12, 2012 11:10 am |
temtronic,
Great comments! Thank you very much, these will totally help! |
cer
Posted: Thu Jan 12, 2012 4:27 pm |
I want it to read adc_channel(1) when the conditions occur but when it is in channel(0), it does not read channel(1) even if the conditions occur. Should i use a "break;" or something at the end of the channel(0) loop?
P.S: I intentionally wrote that adc_channel(0) will be read if bilgi_dis<79. |
