Creating an array
spark
Creating an array
PostPosted: Tue Jan 03, 2012 3:26 pm     Reply with quote
Hello
Is there any possibility to set up an array?
I tried it with the following line, but I failed.
const bit j[][] = {{1,0,0,0,0,0,0,0},{0,1,0,0,0,0,0,0},{0,0,1,0,0,0,0,0},{0,0,0,1,0,0,0,0},
         {0,0,0,0,1,0,0,0},{0,0,0,0,0,1,0,0},{0,0,0,0,0,0,1,0},{0,0,0,0,0,0,0,1}};
How can it be achieved?
PostPosted: Tue Jan 03, 2012 3:32 pm     Reply with quote
You could press F11 while your project is open.
That will allow the onscreen help file to come up. Poke around and you'll find what you need.
or
look at some of the examples that CCS supplies in the 'examples' folder.
again, open,look,read.....easy as 1,2,3
PostPosted: Tue Jan 03, 2012 4:45 pm     Reply with quote
I'm not sure that the compiler supports 2-dimensional bit arrays.
I tested it a little bit and I can't seem to make it work. It compiles
but it doesn't read back the correct data. It wouldn't surprise me
at all if the compiler only supports 1-dimensional bit arrays.
Also, you have it declared as 'const'. The manual says it can create
arrays of bits in RAM only.
spark
PostPosted: Wed Jan 04, 2012 7:46 am     Reply with quote
I am now using a one-dimensional array of bytes.
PostPosted: Wed Jan 04, 2012 10:58 am     Reply with quote
int1 array [][] seem as shown below to work - though with inefficient code in 4.085!!
B U T ----heres what i got with 4.128 LST
.................... int1 Q[8][2]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
01C7:  CLRF   27
01C8:  CLRF   28
....................     if (1==Q[1][1]) Q[1][0]=0;
01E1:  BTFSC  29.1
01E2:  BCF    29.0
so close but so bad.....
this points to a horrific "base 0" fault in the code generation
for var access ... OUCH !!!
It sure looks like a failed attempt in compiler-ville
YET with the compiler being taught to remember where it PUT the
array bytes ;-)) -- a fixed up approach could in future work.
neh ?
help95
PostPosted: Fri Jan 06, 2012 10:45 am     Reply with quote
I've found the 2D arrays are implemented as such:
int h[12][4]={1,0,1,0,
              1,1,1,0,
              1,0,1,0,
              1,0,1,0,
              1,1,1,0,
              1,0,1,0,
              1,0,1,0,
              1,1,1,0,
              1,0,1,0,
              1,0,1,0,
              1,1,1,0,
              1,0,1,0,
This has 12 Rows and 4 Columns. A simple carriage return creates the next row in the array. I have used this for 4 rows and 12 columns and it has worked fine, and have seen examples with 97 rows. http://www.ccsinfo.com/forum/viewtopic.php?t=46854
PostPosted: Fri Jan 06, 2012 11:10 am     Reply with quote
hey help95-
- what compiler version did you use that works OK as you state ??
PostPosted: Fri Jan 06, 2012 11:45 am     Reply with quote
He is using 'int', not 'int1', to declare his array. This thread is about
trying to make a 2-dimensional array of bits. We know a normal byte
array works.
