AD9850 Serial driver with divisor calculation function
Post new topic   Reply to topic    CCS Forum Index -> Code Library
asmboy
PostPosted: Wed Jan 04, 2012 10:39 am     Reply with quote
Edited with code addition for VERY fast 18f pic master clock >24mhz 3/2016
//  AD9850 notes:   be sure to ground reset pin
//  and set Data 0,1,2 per MFG data
//  using fastio for the pic pins is critical
//  to achieve full performance
#define Dlatch pin_B0
#define Dclock pin_C3
#define Ddata  pin_C5
#define DCtog  output_low(Dclock);delay_us(4);output_high(Dclock)
#define DLtog  output_high(Dlatch);delay_us(4);output_low(Dlatch)
// do this ONCE after power on
// init the ad9850 with worst case PLL'd PIC
// 4 us delay not required on pics running at less than 20 mhz w/o PLL
void ad9850_init(void){
     output_low(Ddata);  // MUST be low to init
     delay_us(4); // added 2016 for PIC18 Fosc>6mhz
     DCtog;
     DLtog;
// do I/O to send freq divisor to the ad9850 with zero relative phase
// execution time = 150 usec with 16 mhz PIC  clock
void ad9850_setfreq(unsigned int32 infr){
  unsigned int8 i=0;  unsigned int32 D=0;
  #bit curbit=D.0
  D=infr;   i=0;
  do{  //           send 4 bytes of 32 bit integer,in anti_spi order
    if(curbit) output_high(Ddata );
    else       output_low(Ddata );
    output_high(Dclock);    // raise  LATCH pin
    D >>=1;
    output_low(Dclock);     //  lower LATCH
  }while(++i<32);
  //       this last byte is the 3 control bits and 5 phase bits
  //       defaulting to 0 relative phase for the update
  i=0;  output_low(Ddata);  // clock out 5th control byte=0;
  do{
    output_high(Dclock);  // raise lower LATCH cmd
    i++;
    output_low(Dclock);
  }while(i<8);
  DLtog;   // set data in DDS chip
//  calculates DDS divisor for a 125 mhz DDS clock HOWEVER ---
//  NOTE: this approach LIMITS the useful max freq to less than 12 mhz
//  but has 1 hz resolution
// infreq is the frequency in HZ you want generate the  divisor for
unsigned int32 adc_makedivisor(unsigned int32 Infreq){  // infreq in hz
   return ((34*infreq)+((361*infreq)/1000));
// full 40 mhz version- HOWEVER --- has less resolution
unsigned int32 adc_makedivisorH(unsigned int32 Infreq){  // infreq in hz
   return ((34*infreq)+((36*infreq)/100));
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
