danen
| Stuck in a loop |
Posted: Fri Dec 30, 2011 7:47 am |
Hi
I'm trying to pwm on some leds and then pwm them off. However, the problem I'm having is that the loop runs once and then won't run again.
I toggled an led to see where I was in the loop and it seems to hang at the end of the second loop
What am I missing here.
#include <16F628A.h>
#FUSES NOPUT //Power Up Timer
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES MCLR //Master Clear pin used for I/O
int16 PWM_PIN[]=
PIN_B0,
PIN_B1,
PIN_B2,
#define LOOPCNT 39
int8 width;
int8 x;
width = 0;
x=0;
setup_counters(RTCC_INTERNAL, RTCC_DIV_1);
enable_interrupts(INT_RTCC);
for (x=0;x<=2;x++)
for(width = 0; width <= LOOPCNT; width++)
output_toggle(PIN_B3);
for (x=2;x>=0;x--)
for(width = 39;width <= LOOPCNT; width--)
output_toggle(PIN_B3); // this line does not run
#INT_RTCC
void tick_interrupt(void)
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
loop = LOOPCNT;
pulse = width;
if(pulse)
output_high(PWM_PIN[x]);
pulse--;
output_low(PWM_PIN[x]);
SherpaDoug
Posted: Fri Dec 30, 2011 8:37 am |
int8 x defaults to an unsigned variable so x>=0 must always be true. If you want x to be signed you must declare to as such. _________________ The search for better is endless. Instead simply find very good and get the job done. |
danen
Posted: Fri Dec 30, 2011 10:49 am |
| Thank you for your help I've been racking my brain for three days now. |
