flint
| problem communicating between PIC18f4455 and PIC18f2550 |
Posted: Sun Dec 25, 2011 3:44 pm |
Hi everyone, please I tried communicating between PIC's. I simulated it and it worked but real hardware, when built on a breadboard doesn't work. Any help would be appreciated. Thanks.
Here's the code for the transmitter:
#include <18F4455.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
//#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
//#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#use rs232(baud=57600,xmit=PIN_C6,rcv=PIN_C7,stream=Data)
char Dat='a', Det='b';
Void Transmit() // Transmit data
delay_ms(10);
fprintf(Data,"%c%c\r",Dat,Det); // Transmit Data frame
delay_ms(10); //delay
main()
do {
transmit();
}While(1);
Here's the code for the receiver:
#include <18F2550.h>
#device ADC=8
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES PUT //No Power Up Timer
#use rs232(baud=57600,xmit=PIN_C6,rcv=PIN_C7)
long timeout;
char dataX[2];
timeout=0;
while(!kbhit()&&(++timeout<50000)) //1/2 second
delay_us(10);
timeout++;
if(kbhit())
gets(dataX);
printf("%c%c\r",dataX[0],dataX[1]);
if(dataX[0]=='a')
output_high(PIN_C2);
}else{output_low(PIN_C2);}
Posted: Mon Dec 26, 2011 4:06 am |
First comment - size of dataX....
You are sending two data characters, but the receiver if asked to store a 'string', needs space for the terminating \0 as well, and also if there is any data corruption, there could be even more characters received.
You need to increase the size of dataX, and also consider some way of stopping if the string gets too large (look at input.c, where there is a replacement for gets, that allows you to limit the maximum string length).
Second, add 'ERRORS' to your RS232 definitions. This _must_ be present when using the hardware UART, unless _you_ handle overrun and framing errors yourself. Without this the receiving UART can get hung.
Third, your timeout code won't work. Remember unless you use brackets, only the line after the while gets executed, so the timeout increment never happens...
Then remember that if a timeout has taken place, the string will contain what was in it last time. Consider clearing dataX[0] before waiting, if you want the pin to reflect that a timeout has happened.
flint
Posted: Mon Dec 26, 2011 12:18 pm |
| Ttelmah wrote: | First comment - size of dataX....
Best Wishes | Hi thanks for your prompt reply, have applied your first and second observations before posting this problem, yet it didn't work( it works on simulation). Could you please shed more light on how I can add "ERRORS" to the UART? It would be appreciated. |
Posted: Mon Dec 26, 2011 12:26 pm |
| Quote: |
Download the CCS manual. Look in the #use rs232() section. It explains
all the parameters, including the ERRORS parameter.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf |
flint
Posted: Mon Dec 26, 2011 1:29 pm |
| flint wrote: | | Ttelmah wrote: | First comment - size of dataX....
please how can i load the proteus image of the hardware so that it could be scrutinized to check were am missing it? |
Posted: Mon Dec 26, 2011 1:36 pm |
quickly..
you save the image on a 3rd party image website, then in the message here embed the 'link' to the image.. |
flint
Posted: Mon Dec 26, 2011 5:47 pm |
Have applied all your observations, yet its not working. I used wires to connect the TX and RX pins of the sender (PIC18f4455) directly to the RX and TX pins of the receiver (PIC18f2550) respectively. Really need help urgently. Thanks.
code for Transmitter | Code: |
#device adc=8
//#use fixed_io(c_outputs=pin_C6) //speeds up port use
delay_ms(10);
fprintf(Data,"%c%c\r",Dat,Det); // Transmit Data frame to PIC18f2550
main()
transmit();
Reciever
#device ADC=8
#use rs232(baud=57600,xmit=PIN_C6,rcv=PIN_C7,stream=data)
char dataX[20];
int1 timeout_error;
long timeout;
timeout_error=FALSE;
timeout=0;
while(!kbhit(data)&&(++timeout<20000)) // wait for char or timeout
delay_us(1);
timeout++;
if(kbhit(data))
gets(dataX);
timeout_error=TRUE;
if(dataX[0]=='a')
output_high(PIN_C0); // turn on LED connected to pin C0
output_low(PIN_C0); // turn off LED
Posted: Mon Dec 26, 2011 6:32 pm |
| Quote: | Have applied all your observations
Wrong. You still don't have ERRORS in the #use rs232() statements.
| Quote: | I used wires to connect the TX and RX pins
Do you also have a ground connection between the two boards (or the
two PICs) ? You need one. |
flint
Posted: Mon Dec 26, 2011 6:38 pm |
| PCM programmer wrote: | | Quote: | Have applied all your observations
the two boards share a common VCC and GROUND. please i would appreciate it if you can edit the code and repost it, or send a working code. thanks |
ezflyr
Posted: Tue Dec 27, 2011 9:00 am |
Until you've got the basic communications working between your boards, your code is way too complicated! On the transmit side, just send a single character repeatedly with a short delay between transmissions. On the receive side, grab the character with fgetc, and then use fputc to send it out to your PC so that you can see what is actually being received. Get rid of all the array stuff, and the character processing. Once you've got that working, you can expand the code to send multiple characters, process the received characters, etc.
One note, I basically never use the gets function. It's much safer to use getc and read the characters in one-by-one. The gets function will wait endlessly for the null terminator at the end of a string, and if it does not arrive, your code will hang! This function should only be used if you are absolutely sure you'll always be receiving a complete string!
The only way you are going to learn anything is to solve these problems yourself, the solution has been complete laid out for you, but you've got to do the work!
John |
flint
Posted: Sat Jan 14, 2012 7:41 pm |
| ezflyr wrote: | Hi,
John |
Thanks everyone, i reduced the code to light just a single led, and its working fine, also, i included the "errors" in the uart. would work my way up!
You're appreciated. Big thanks to you all. |
