acidice333
Posted: Tue Nov 29, 2011 2:47 am |
Just curious how do you calculate for 48mhz? its probably right in front of me and I just dont understand. Much appreciated thanks!
| Quote: |
/* TIMER0 configuration */
#define TIMER0_CONFIG RTCC_INTERNAL | RTCC_DIV_1
/* Interrupt rate: */
/* 4/32000000*65536*1 = 8.192 ms */
/* Start: 3.0 ms (ignored) */
/* "1": 1.8 ms (14400) */
/* "0": 1.2 ms (9600) */
#define ONE_MIN 13400
#define ONE_MAX 15400
#define ZERO_MIN 8600
#define ZERO_MAX 10600
sahu77
Posted: Fri Dec 23, 2011 11:19 am |
Anybody can convert it code in RC5 for help me .... _________________ sahu |
masterat
Posted: Tue Jan 03, 2012 1:33 am |
| acidice333 wrote: | Just curious how do you calculate for 48mhz? its probably right in front of me and I just dont understand. Much appreciated thanks!
48 Mhz Should be:
/* 4/48000000*65536*1 = 5.46125 ms */
/* "1": 1.8 ms (21600) */
/* "0": 1.2 ms (14400) */
#define ONE_MIN 22600
#define ONE_MAX 20600
#define ZERO_MIN 13400
#define ZERO_MAX 15400 |
rdoradus
| answer |
Posted: Mon Jan 07, 2013 10:18 pm |
The answer for HTAluvBeBeo is only work with #fuses. I compile the code for send with RS-232 and proved with pickit2 clone and it works great
I have written next fuses in header:
| Code: | #include <18f4550.h>
#FUSES HS,NOWDT,WDT128,NOPROTECT,NOBROWNOUT,BORV20,PUT,MCLR,NOCPD,NODEBUG,NOLVP,NOWRT,NOWRTD,NOWRTB,NOEBTR,NOEBTRB,NOCPB,NOWRTC,NOFCMEN,NOPBADEN,PLL1,CPUDIV1,USBDIV,VREGEN,ICPRT,STVREN,NOIESO,LPT1OSC,NOXINST
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B6)
#use fast_io(B)
/* 4/20000000*65536*1 = 13.1072 ms 5.46125 */
/* "1": 1.8 ms (9000) 7.28177777 */
/* "0": 1.2 ms (6000) 10.922666 */
#define ONE_MIN 8000
#define ONE_MAX 10000
#define ZERO_MIN 5000
#define ZERO_MAX 7000 |
All extra code equal...
Crystal of 20MHz PIC18F2550 and RS-232 from Pickit2 clone. |
loctip
| Re: Infrared receiver for SONY remotes |
Posted: Sun May 12, 2013 10:33 pm |
| Code: | /* Interrupt rate: */
Plz show me how to calculate these datas !
Thanks a lot
14400 9600 |
