PIC18F46K22 Compiler Problem?
picnic
PostPosted: Wed Dec 21, 2011 10:06 am     Reply with quote
I've been trying to use the Weak Pull-up feature of Port B, I got erroneous results. Examining the ASM output showed the compiler using the wrong register value for the port_b_pullups() call.
Also GETENV("SFR:TXSTA1") gives 0. Have I got the name wrong or is this (and maybe its ilk) missing?
Compiler version 4.127
PostPosted: Wed Dec 21, 2011 2:27 pm     Reply with quote
Put the following 4 lines above main(). This macro (with the #define
statement) will replace the buggy built-in port_b_pullups() function:
#byte WPUB = 0xF61
#byte INTCON2 = 0xFF1
#bit RBPU = INTCON2.7
#define port_b_pullups(x)  WPUB = x;  x ? (RBPU = 0) : (RBPU = 1);
I didn't get that. If I compile the program shown below with vs. 4.127
and look at the .LST file, I see this:
.................... result = TXSTA1;
00032: MOVFF FAC,05
0xFAC is the correct register address of TXSTA1 in the 18F46K22.
This was tested with vs. 4.127.
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#byte TXSTA1 = getenv("SFR:TXSTA1")
int8 result;
result = TXSTA1;
PostPosted: Wed Dec 21, 2011 4:08 pm     Reply with quote
Though the posted version of GETENV should work, there have been problems reported with the latest compilers, being 'strict' about the presence of spaces or tabs. So if you use a tab between the '=' and the GETENV, problems have been seen, and if extra spaces are added some problems also seem to occur. Type it exactly as PCM_programmer has it, and it does work.
picnic
PostPosted: Thu Dec 22, 2011 2:53 am     Reply with quote
Thanks for the help guys Smile
