gokulrred
| unexpected output during SPI communication |
Posted: Wed Dec 21, 2011 3:55 am |
i developed the following coding.
what i wanted:
two LEDs at D6, D7 has to blink thrice each on after the other.
then both LEDs blink thrice at the same time....
then it has to settle down at both "GLOW"...
What i got:
the above i got... but the code runs indefinitely without stopping...
in other words: the output gets repeated continuously as if it is in while(1) loop..
doubts:
whether i need to work on its SSPCON?????
note:
i have used D port for SPI communication....
having outputs at D port and spi at the same D port will cause any prob?
MASTER:
| Code: | #include <18f4431.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#fuses SSP_RD
#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1 (SPI_L_TO_H)
#define SPI_MODE_2 (SPI_H_TO_L)
#define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
int a,b,c,d;
setup_spi(SPI_MASTER | SPI_MODE_1 | SPI_CLK_DIV_64);
enable_interrupts(INT_SSP);
for(b=0;b<3;b++)
a=0x80;
spi_write(a);
a=0x81;
spi_write(a);
for(b=0;b<3;b++)
a=0x82;
spi_write(a);
a=0x83;
spi_write(a);
a=0x82;
spi_write(a);
SLAVE:
#fuses HS,NOWDT,NOLVP,NOPROTECT
#fuses SSP_RD
int val1, val2,i,check;
#int_SSP
SSP_isr()
val1 = spi_read();
if(val1==0x80)
output_bit(PIN_D6,1);
output_bit(PIN_D7,0);
if(val1==0x81)
output_bit(PIN_D6,0);
output_bit(PIN_D7,1);
if(val1==0x82)
if(val1==0x83)
setup_spi(SPI_SLAVE | SPI_L_TO_H|SPI_SS_DISABLED);
THANKS IN ADVANCE.......
Posted: Wed Dec 21, 2011 4:25 am |
You must _never_, repeat _never_ have an interrupt fully enabled (both it and global enabled), without a handler.
Doing so will result in the code looping back to an unexpected location, and may cause anything to happen.
You also don't generally want/need INT_SSP on a master device.
INT_SSP is triggered whenever a byte arrives in the SSP buffer. Since this only happens when the master has sent a byte, it knows already that a byte is there, and the interrupt is 99% pointless.
Get rid of enabling INT_SSP on your master,and see if things improve....
gokulrred
Posted: Wed Dec 21, 2011 4:52 am |
EXTRAORDINARY ............
AMAZZZZIIIINGGGGGGGGGGGGGGG.....
THE PROB SOLVED.........
ITS GETTING EXECUTED ONLY ONCE...
THANK U VERY MUCH TTELMAH....... |
