Hi. I want to know if exists a instruction that permit convert a decimal number to a binary. My problem is that I receive a data from rs232 in decimal and I need it in binary.
thanks all
Posted: Sun Dec 18, 2011 10:49 pm
Do you mean the decimal data is in ASCII character form? _________________ Google and Forum Search are some of your best tools
Gabriel
Posted: Mon Dec 19, 2011 7:08 am
as mentioned before, you need to be clear if the data is comming as ASCII or not..
if its ascii numbers, just substract 30...(0-9) - for letters... its somthing similar...
please take into acount that once you "translate" your Ascii to hex, its already in binary....
you can perform bitwise operations on hex numbers...like if they where binary... although you "see" 0xAB you in reality have "b10101011"
the complier does all the work for you...
int x = 10; // Dec
int x = 0x0A; // Hex
int x = b00001010; // bin
