Problem to write coding for RFId. Someone Help me =(
fidaus2005
View user's profile Send private message AIM Address ICQ Number
PostPosted: Fri Dec 16, 2011 9:52 pm     Reply with quote
Olimex Mod-RFID125
Pic= 16F877A
http://www.olimex.com/dev/mod-rfid125.html
PostPosted: Sat Dec 17, 2011 6:13 am     Reply with quote
Easy enough, as Olimex supplies all the command line code information on page 5 or 6 of the datasheet.pdf.
If you want complete test code(scan for rfid tags, display on local LCD, send to PC via RS232 just send me 4 units and give me 1 week to complete the program.
ezflyr
PostPosted: Sun Dec 18, 2011 8:38 am     Reply with quote
Temtronic,
Ummm, that module requires a USB host, so you aren't likely to get that done with a 16F877A unless you use an FTDI Viniculum chip, or equivalent. Of course, there are PIC's that can operate as a USB host, but that going to take a lot of work!
To the OP, if you want to play with RFID stuff, get a module with a serial port like this one: http://www.sparkfun.com/products/8419
John
PostPosted: Sun Dec 18, 2011 8:50 am     Reply with quote
Hay John. There's actually ttl serial pins on the other end, hard to see, but the pdf does talk about them. You'ld have to add wires or hopefully 100thou spaced pins to connect.
I know that cause silly me I downloaded and read the manual...
Jay
fidaus2005
PostPosted: Sun Dec 18, 2011 10:29 am     Reply with quote
That correct this rfid can be connected to the circuit because it have UART mode.. but i m new in this pic field.. so i dont know how to start coding it hu3
ezflyr
PostPosted: Sun Dec 18, 2011 3:59 pm     Reply with quote
Hi Jay,
Manual? We don't need no stinkin' manual Cool !
You are, of course, correct! I should have read more than just the first couple of lines of the datasheet Embarassed !
Having said that, it's still a much more capable module (in terms of the interface) than the Sparkfun example, so it may also be more expensive? It also is not particularly breadboard or PCB friendly.
Making that module work, though, looks pretty trivial. There are only a couple of very simple commands to worry about!
To the OP, have you tried sending simple commands to the module, and reading the returned data? What happens? What is the nature of your "problem"?
John
