RC5 is high on power-up
kender
PostPosted: Thu Dec 15, 2011 5:58 pm     Reply with quote
Folks,
When I was setting up the internal OpAmp in PIC16HV785, I’ve noticed that RC6 was high on power-up. There was no additional initialization to the simple project wizard generated initialization (I can post my code).
I found a workaround. input(PIN_C6) removes the logic high output and the OpAmp1 works as expected.
 input(PIN_C6);
setup_opamp1(TRUE);
I wonder why RC6 was high in the first place?
- Nick
16HV785
PCWH 4.081
Read the label, before opening a can of worms.
PostPosted: Fri Dec 16, 2011 3:49 am     Reply with quote
You need to show us what else you are configuring before this point. For some reason the output driver is being switched on (output_float(PIN_C6) would also solve the problem).
What compiler version?.
