bbld
| receiving problems with uart interrupt |
Posted: Wed Dec 14, 2011 10:43 am |
hi everyone (i'm sorry if my english's not good enough)
i have a project with Sim300cz,
i want to receive string from sim300cz to MCU and then show it on my PC(through hyperterminal).
and hyperterminal show nothing.
here my code,any ideas?
please help me.
i use pic18f97j60
and ccs ver 4.105
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7,stream=SIM300)
#use rs232(baud=9600,xmit=pin_g1,rcv=pin_g2,stream=HOSTPC)
char *Data1 ,*Data2,L1[41],L2[41],L3[41],L4[41];
int i;
#define TX1 PIN_C6
#define RX1 PIN_C7
//-------CH2-------- (For USE PC interfacce)
#define TX2 PIN_G1
#define RX2 PIN_G2
#INT_RDA
void IntRDA_isr(void)
#use rs232(baud = 9600, xmit = TX1, rcv = RX1)
data1=getc(); //data1 is pointer
#use rs232(baud = 9600, xmit = TX2, rcv = RX2)
putc(data1);
if(data1 != 13){ //CR : Carry return
if(data1 != 10){ //LF : Line Feed
L1[cn] = data1; //initial cn=0
cn++;
if(cn >= 40 )cn = 0;
else{
cn = 0;
Clr_msgL4();sprintf(L4,L3);
Clr_msgL3();sprintf(L3,L2);
Clr_msgL2();sprintf(L2,L1);
Clr_msgL1();
//L1
for(i=0;i<40;i++){fprintf(HOSTPC,">L1[%d]=%c\n\r"i,L1[i]);delay_ms(10);}
fprintf(HOSTPC,"\n\r");
//L2
for(i=0;i<40;i++){fprintf(HOSTPC,">L2[%d]=%c\n\r"i,L2[i]);delay_ms(10);}
//L3
for(i=0;i<40;i++){fprintf(HOSTPC,">L3[%d]=%c\n\r"i,L3[i]);delay_ms(10);}
//L4
for(i=0;i<40;i++){fprintf(HOSTPC,">L4[%d]=%c\n\r"i,L4[i]);delay_ms(10);}
bbld
Posted: Wed Dec 14, 2011 10:49 am |
I can:
+send data:MCU->PC;PC->sim300cz;MCU->sim300cz
+receive data:MCU->PC;Sim300cz->PC
I think i have problem with receive data from uart interrupt.
It seems to receive nothing.
Any helps?
How can i receive data from uart interrupts in my ccs? |
Joined: 01 Jul 2010 Posts: 9606 Location: Greensville,Ontario
Posted: Wed Dec 14, 2011 10:59 am |
some quick comments...
1) always add 'errors' to the use rs232(...) options when using hardware UARTs
2) the USE RS232(...) lines should be outside the ISR, in the 'main' code, in the 'setup' section
3)ISR routines MUST be SHORT and FAST. Those sprintf(...) lines must be in MAIN NOT the ISR.Also get rid of the clr_msg.. functions as well.Have the ISR set 'flags' that the code in MAIN deals with.
4) Why have the delay_ms(10) in the printf(..) code ? It sohouldn't be necessary. |
bbld
| thanks for your help temtronic |
Posted: Wed Dec 14, 2011 11:29 am |
thanks for your help.but when i try with simple code.just send data from my pc to mcu and back to pc through interrupts.
data from mcu send to pc ok
but serial interrupt doesn't work anymore.pc shows nothing.
i think i got a promblem with function getc or something like this.
so you have any ideas?
thanks
#use delay(clock = FREQ_OSC)
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7,errors)
#int_rda
void rda_isr(void)
char c;
c = getc();
putc(c);//send to pc to test interrupt receives data,but show nothing
delay_ms(2000);
printf("hello world\n\n");//show on hyperterminal ok
enable_interrupts(INT_RDA);
Posted: Thu Dec 15, 2011 3:29 am |
OK.
There is a fault with the fuses in your compiler version (and several afterwards), that enables the extended CPU mode, even if you select the fuses to not enable this mode. Makes a lot of code not work properly....
I manually override the first five fuses, with:
#ROM 0x300000 = {0xF4A0}
Which is the pattern for:
NOWDT STRVEN NOXINST, and code protect off, to make the code work
Try adding this to your code after your fuses, and see if it starts working.
bbld
| thanks for your help,mr.Ttelmah |
Posted: Thu Dec 15, 2011 5:29 am |
i will try it.
thanks for your support.
i''m very appreciate that. |
bbld
| hi mr.Ttelmah |
Posted: Thu Dec 15, 2011 9:32 am |
I had tried to add fuses with your suggestion, but not effect.
I can send data to pc, but i cannot use the uart interrupt. Please help me.
I use pic 18f97j60.
So this's exact my code:
#include <stdlib.h>
#include <stdio.h>
//#ROM 0x300000 = {0xF4A0}//with it i had warning code is lager than device
#use delay(clock=25000000)
#fuses HS // Oscillator mode HS
#fuses NOWDT
//#fuses NOLVP // my ccs 4.105 not compile this code,it made error
#fuses NOPROTECT,NOXINST
#use fast_io(G)
char c;
#define TX PIN_G1
#define RX PIN_G2
#use rs232(baud=9600,xmit=pin_g1,rcv=pin_g2,errors)
#int_rda
void rda_isr(void)
char c;
c = getc();
putc(13);
putc(13);
printf("test ok");
set_Tris_g(0x04);
delay_ms(2000);
printf("hello world\n\r");//show on hyperterminal ok
best regards |
Posted: Thu Dec 15, 2011 10:03 am |
while I don't have that PIC a couple of comments...
1) put enables in main BEFORE the 'forever loop' as shown below..
set_Tris_g(0x04);
delay_ms(2000);
2) get rid of the set_tris(...); code
Let the compiler do it's job and set what is required ,when.If you make an error , odds are the program 'will not work'.
3) disable any peripheral associated with your xmt/rcv pins.
4) check the listing to be sure the compiler has selected the correct serial pins.
5) get rid of the #includes as you're not using anything from them...that I know of...
6) get rid of the fast_io()...Again let the compiler do all the real work!
7) use the CODE button when posting your code, it makes life a LOT easier for all of us in trying to help you.
8) there may be a 'default' for the RS232 stuff, check the PIC.H file to see ? |
bbld
| thanks for your help mr.temtronic |
Posted: Thu Dec 15, 2011 10:57 am |
i will try it.
thanks for your helps mr.temtronic.
best regards |
Posted: Thu Dec 15, 2011 1:06 pm |
Whoa a sec.
Your original 'small example', had the pins in use as C6 and C7. _These are the only pins you can use to get an INT on INT_RDA_.
Your new code uses G1, and G2.
You _must_ set the clock, and fuses _before_ including things like STDIO.
However your code does not use either of the include files you are loading...
You should not get a warning about the code being larger than the device - the reason you are getting this is as posted, the device has not been defined at this point. It _must_ be the first thing done.
Your interrupt _must not_ take longer than one character time to execute. Printing one character is OK, more is not.
The following, compiles, and runs:
#include <18F97J60.h>
#device adc=8
#FUSES NOWDT, HS, NODEBUG, STVREN, NOPROTECT, NOFCMEN, NOIESO, PRIMARY, ECCPE, NOETHLED, NOWAIT, BW16, EASHFT, NOXINST, MCU
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#int_rda
void rda_isr(void) {
char c;
c = getc();
putc(c);
void main(void) {
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_spi2(FALSE);
setup_wdt(WDT_OFF);
delay_ms(2000);
do {
delay_us(100);
} while(TRUE);
G1, and G2, are the _second_ UART, and will generate INT_RDA2, not INT_RDA.
bbld
Posted: Thu Dec 15, 2011 11:03 pm |
| Ttelmah wrote: |
#device adc=8
#int_rda
char c;
c = getc();
putc(c);
void main(void) {
setup_spi(FALSE);
setup_spi2(FALSE);
setup_wdt(WDT_OFF);
delay_ms(2000);
do {
delay_us(100);
} while(TRUE);
wow,i'm very appreciate your help mr.Ttelmah,it works.
thank you very much. |
bbld
Posted: Thu Dec 15, 2011 11:57 pm |
#device adc=8
#ROM 0x300000 = {0xF4A0} |
your header code is really helpful for me.
thanks again.
best regards |
