Test GPIO 16F1823
Noland
Test GPIO 16F1823
PostPosted: Sun Dec 11, 2011 10:05 am     Reply with quote
Hello. I'm Palm in writing codes at CCS C. PIC 16f1823, I can't control PIC16f1823 is GPIO. How to set up 16f1826 GPIO ?
  #include <16F1823.H>
    #fuses  INTRC_IO,NOWDT,NOPROTECT,MCLR
    #use    delay(clock=8M)
    #use    fast_io(A)
    #byte   PORTA   = 0x00C
    #byte   TRISA   = 0x08C
    #byte   ANSELA  = 0x18C
    #byte   LATA    = 0x10C
       setup_oscillator(OSC_8MHZ|OSC_PLL_ON);
       //setup_oscillator(OSC_8MHZ | OSC_NORMAL | OSC_PLL_ON);
      ANSELA = 0x00;
      TRISA = 0b00000111;
          LATA = 0b00000000;
          delay_ms(1600);
          LATA = 0b00000111;
          delay_ms(1600);
and
    #use    fast_io(A)
    #byte   PORTA = 0x00C
    #byte   TRISA = 0x08C
    #byte   LATA = 0x10C
      set_tris_A (0x08);
      ANSELA = 0x00;
      TRISA = 0b00000000;
          output_a(0x00);
          delay_ms(1600);
          output_a(0xff);
          delay_ms(1600);
This codes don't work
PostPosted: Sun Dec 11, 2011 10:49 am     Reply with quote
Seriously, just use the compiler!.
The tris register is already available for your without any register defines, so it the latch register.
    #use    fast_io(A)
    void main(void) {
      setup_oscillator(OSC_8MHZ|OSC_INTRC); //setting for 8MHz
      // - if you want the
      //PLL change the clock to match, or the timings will be wrong.
      set_adc_ports(NO_ANALOGS);
      setup_adc(ADC_OFF);
      set_tris_a(0b00000111);
       while(TRUE) {
          output_a(0b00000000);
          delay_ms(1600);
          output_a(0b00000111);
          delay_ms(1600);
If you want to write assembler, use assembler, but with the compiler just use the compiler functions unless you _must_ work directly.
PostPosted: Sun Dec 11, 2011 1:23 pm     Reply with quote
If you can't make it work with CCS functions, then post your compiler version.
Noland
PostPosted: Sun Dec 11, 2011 8:59 pm     Reply with quote
CCS V.4.107 Now, don't work and All Pin PortA output 2.4V stable
PostPosted: Mon Dec 12, 2011 1:16 am     Reply with quote
I'll test it in hardware, tomorrow morning with your version.
Noland
PostPosted: Mon Dec 12, 2011 3:31 am     Reply with quote
I test...
PIC Work, If set portA output_high or output_low
PIC don't work, If set portA output_high output_low Alternate output at portA is 2.4V stable
I think it's set x-tal Wrong.
I trial Ext and INT x-tal
PostPosted: Mon Dec 12, 2011 1:32 pm     Reply with quote
How are you testing this ? Are you using an oscilloscope or a voltmeter ?
Because if you are using a voltmeter, it might be averaging the alternating
waveform into the average voltage. If goes between 0v and 4.8v,
equally for each half-cycle, the average will be 2.4 volts. Is that what
you are doing ? Are you using a voltmeter ?
Noland
PostPosted: Mon Dec 12, 2011 7:40 pm     Reply with quote
 output_a(0xff)
 delay_ms(2000);
 output_a(0x00)
 delay_ms(2000);
using a voltmeter Because using delay 2000 ms and test at delay 10000 ms pic don't work
the output should be 0-4.8V (0 1 0 1....)
but the output is 2.4V stable
PostPosted: Mon Dec 12, 2011 8:36 pm     Reply with quote
Unfortunately I had to be out of the office almost all day (unexpectedly).
I believe I will be able to test it in hardware on Tuesday morning.
PostPosted: Tue Dec 13, 2011 1:23 pm     Reply with quote
I looked at the .LST file and tested it in hardware.
Vs. 4.107 is just terrible for the 16F1823. It's missing half the fuses.
The .h file only lists some of the actual fuses in the PIC. The compiler
doesn't use the 2nd Config Word. It doesn't really know that it exists.
The delay_ms() routine doesn't work. It just returns quickly, maybe
doing a delay of a little more than 10 usec, when you call delay_ms(1).
There are so many things wrong that I don't want to try to make
work-arounds for all the bugs in vs. 4.107 for the 16F1823.
It would be better if you upgraded the compiler.
I think the reason for this is because the waveform runs at 30 KHz or
higher (because of the bad delay_ms code), so the voltmeter just
averages it to 2.4v.
I'll do one work-around:
I've done a very quick replacement for delay_ms() which will work
for 4 MHz oscillator frequency. It uses delay_cycles(), which takes
1 usec at 4 MHz, so delay_cycles(250) gives a delay of 250 usec.
4 x 250 = 1000 usec = 1 ms delay. When the work-around function
is written as a macro (with a #define statement) then it will replace
the existing built-in function, as shown below:
#use delay(clock=4M)
int16 cnt;
#define delay_ms(x)    \
cnt = x;                  \
   while(cnt)             \
       delay_cycles(250); \
       cnt--;             \
   output_a(0x00);
   delay_ms(1600);
   output_a(0xff);
   delay_ms(1600);
Noland
PostPosted: Tue Dec 13, 2011 10:17 pm     Reply with quote
Thank you very much. now pic work
Noland
PostPosted: Fri Dec 16, 2011 2:20 am     Reply with quote
If use XTAL=8MHz PLLx4 = 32MHz I will write delay_cycles(??); ??.
int16 cnt;
cnt = x;                  \
   while(cnt)             \
       delay_cycles(??); \
       delay_cycles(??); \
       delay_cycles(??); \
       delay_cycles(??); \
       cnt--;             \
   output_a(0x00);
   delay_ms(1600);
   output_a(0xff);
   delay_ms(1600);
PostPosted: Fri Dec 16, 2011 1:07 pm     Reply with quote
This is one way to do it. Because 32 MHz is 8x faster than 4 MHz, just
put in a for() loop that calls the same delay block for 8x.
#use delay(clock=32M)
int8 i;
int16 cnt;
cnt = x;                       \
   while(cnt)                  \
       for(i=0; i<8; i++)      \
       cnt--;                  \
   output_a(0x00);
   delay_ms(1600);
   output_a(0xff);
   delay_ms(1600);
If you need any more work-arounds for this compiler version with this
PIC, you need to learn how to do it.
