Single line text scrolling on LCD ?
leaveme
PostPosted: Sat Dec 10, 2011 10:48 pm     Reply with quote
I'm using following code for left/right text scrolling. But they are handling both the lines at the same time. Anybody can suggest anything so that I can scroll only single line ?
lcd_send_byte(0, 0x1E);
lcd_send_byte(0, 0x18);
Thank you.
PostPosted: Sun Dec 11, 2011 7:32 am     Reply with quote
Easy to do...
First create 2 16 byte 'buffers'(arrays) and copy the text you want to scroll from your program to the first .
Second, copy the data from the first buffer to the second,offsetting the indices(pointers).
Now move the data from the 2nd buffer to the LCD.
to scroll left to right..
outputbuffer[2]=inputbuffer[1].
to scroll right to left
ouputbuffer[2]=inputbuffer[3].
if you want the message to 'loop' around, copy [0] to [15] !
..actual code is up to you to do.
If you try it on graphpaper, it'll be easy to visualize the 'flow' of the code.
