Regarding arbitrary changes
FvM
PostPosted: Sat Dec 10, 2011 8:33 am     Reply with quote
To make my existing code compile with PCD V4.128, I needed to add one more conditional
#IF  getenv("VERSION")>=4.128
   #asm
   CP W0,2
   #endasm
#ELSE
   #asm
   CP 2
   #endasm
#ENDIF
But why?
Not enough, that you need to figure out the correct assembler syntax yourself, because the manual doesn't
tell it correctly, you also need to change it from time to time... Helps to keep an agile mind at least.
I'm going to check now, if V4.127 functionality has been preserved. Someone making a bet?
FvM
More assembler changes
PostPosted: Mon Sep 17, 2012 3:59 am     Reply with quote
Does someone know a syntax for the below statement accepted in PCD V4.134 or above?
I didn't yet succeed to guess one (or there's none at all).
#asm
CP.B W0,#1
#endasm
Regards,
Frank
