INT ext
Goto page 1, 2  Next
aaronik19
INT ext
PostPosted: Mon Dec 05, 2011 3:42 pm     Reply with quote
Dear all,
I made this small program and unfortunately the INT EXT is not working and the RB Interrupt is working fine. PIC used is 16f876 on 4MHz crystal.
#include <garage.h>
#int_RB
void  RB_isr(void)
if(input(PIN_B4) )
   output_A(13);
if(input(PIN_B5) )
   output_A(17);
if(input(PIN_B6) )
   output_A(18);
#int_EXT
void  EXT_isr(void)
if(input(PIN_B1) == 1 )
   output_A(02);
if(input(PIN_B2) == 1 )
   output_A(03);
if(input(PIN_B3) == 1 )
   output_A(04);
#int_TIMER1
void  TIMER1_isr(void)
   set_tris_b(0xff);
   set_tris_a(0x00);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //524 ms overflow
   enable_interrupts(INT_RB);
   enable_interrupts(INT_EXT);
   sleep();
thanks for your help
PostPosted: Mon Dec 05, 2011 4:49 pm     Reply with quote
you have potentially troublesome overlap here :
1- i will assume U know the EXT int is triggered by pin B0 not B1
2- also i ALWAYS do a full READ of port_B
dumi=input_b();
before exiting the ISR to avoid hanging / missed int problems
personally i would do this with BOTH ISRs that you show
3- i would do a CLEAR_INTERRUPT() call to each int you enable
BEFORE enabling them in your INIT startup routine
4- lastly and i would NOT have the timer ISR call an empty routine
PostPosted: Mon Dec 05, 2011 5:02 pm     Reply with quote
1. Describe the external circuit on pin B0 (for INT_EXT).
2. What are the voltage levels placed on pin B0 by this circuit ?
3. What is the Vdd voltage of the PIC ?
4. What are your #fuses ?
5. What is your compiler version ?
It doesn't do any harm.
aaronik19
PostPosted: Tue Dec 06, 2011 1:38 am     Reply with quote
thanks for your reply asmboy and PCM Programmer.
I am using PIC16F876, 4MHz, and the supply voltage is constant 5V. I know that the EXT works on B0 but I've put diodes to B1, B2, and B3 (instead of OR gates) to have three inputs on the EXT. I am 100% that the design is correct, do not worry Smile
the compiler I am using is the 4.093. Is this makes any difference?
Why I should clear interrupts before enable them? To be 100% sure that everything is clear? I've never hear this before but if this is the case, it makes sense...thanks.
PostPosted: Tue Dec 06, 2011 4:07 am     Reply with quote
A lot of interrupts can get 'accidentally' triggered when you initialise the chip. For instance, the edge triggered interrupts may get set if you change the edge they are programmed to use. Timers may roll over after the chip wakes (typically they start at 0xFFFF, so a roll over to '0' happens with just one clock cycle). Things like RS232 inputs may see the input drawn low for a few uSec before buffer chips like the MAX232 wake up. So it is always 'safer' to assume they may well be set at boot, or write the handler so it doesn't matter if they do accidentally trigger.
Now, are you sure you are using the right 'edge' for INT_EXT?. Unlike the RB interrupt, which triggers on both edges of a signal, this only triggers on one. You are testing for pins being high, so you need to have the interrupt trigger on the 'low to high' edge, or this will never be the case. Look at the ext_int_edge setting.
PostPosted: Tue Dec 06, 2011 4:20 am     Reply with quote
You have not configured for the INT_EXT to be triggered by the rising or falling edge.
I don't know the default setting, but lets assume it is the falling edge, then your INT_EXT interrupt will fire but reading of the B1 to B3 pins will always be 0 and nothing is being output.
For testing this I suggest you add an extra test to the INT_EXT routine where you output a value when B1-B3 all are zero.
Edit: I see Ttelmah posted a similar reply while I was typing this.
aaronik19
PostPosted: Tue Dec 06, 2011 10:50 am     Reply with quote
thanks to all,
I've replaced the following code:
#int_EXT
void  EXT_isr(void)
   output_A(02);
   output_A(03);
   output_A(04);
with this:
#int_EXT
void  EXT_isr(void)
value = input_b();
if(value = 0b00000011)
   output_A(02);
if(value = 0b00000101)
   output_A(03);
if(value = 0b00001001 )
   output_A(04);
but still no luck. I also inserted the ext_edge (l_to_h) but still not working. Any help please?
PostPosted: Tue Dec 06, 2011 10:55 am     Reply with quote
Two problems:
Unless you _know_ the values of the top four bits are going to be '0', again 'of course' it won't work.
It also won't work, because '=' is the value assignment operator, not the 'test' operator '=='.
if ((value & 0xF) == 0b0000011)
aaronik19
PostPosted: Tue Dec 06, 2011 11:36 am     Reply with quote
yes, I inserted "==" and not "="..it was a misprint. still no luck with
if((input_val& 0xF) == 0b00001001)
   output_A(04);
PostPosted: Tue Dec 06, 2011 11:51 am     Reply with quote
Still, you have not added debug code for the situation where none of the inputs is what you expect them to be. Now you assume the interrupt is not working where it very well might work but with different input values.
One reason for different input values is the edge on which INT_EXT is triggered. You, again, assume it is the positive edge but nowhere in your code this is configured so it might as well be the triggered by the negative edge. Ttelmah gave you a hint for the command to change this setting.
aaronik19
PostPosted: Tue Dec 06, 2011 12:06 pm     Reply with quote
sorry I always forget to put the whole code. Here it is:
//variables
byte input_val;
#int_RB
void  RB_isr(void)
if (input(PIN_B4))
   output_A(13);
if(input(PIN_B5) )
   output_A(17);
if(input(PIN_B6) )
   output_A(18);
#int_EXT
void  EXT_isr(void)
 if (INPUT(PIN_B1))
   output_A(30);
#int_TIMER1
   set_tris_b(0xff);
   set_tris_a(0x00);
   ext_int_edge( h_TO_l );
   clear_interrupt(INT_RB);
   clear_interrupt(INT_EXT);
   clear_interrupt(INT_TIMER1);
   sleep();
aaronik19
PostPosted: Tue Dec 06, 2011 12:08 pm     Reply with quote
the code that I submitted is the latest one I am experiment in...
PostPosted: Tue Dec 06, 2011 1:15 pm     Reply with quote
you are still not initializing fully
WHICH direction of change will take the INT ISR????????
aaronik19
PostPosted: Tue Dec 06, 2011 1:59 pm     Reply with quote
sorry asmboy but I am not understanding you. What do yo mean by "initializing fully "?
newguy
PostPosted: Tue Dec 06, 2011 2:15 pm     Reply with quote
The edge interrupt(s - depending on processor) can be configured to trigger on either a rising or falling edge. Look up ext_int_edge() in the help file.
Goto page 1, 2  Next
Page 1 of 2
