		| Author | Message |
		| peer9802
				| Potential issue with PIC16F1823 internal oscillator |
				|  Posted: Wed Nov 23, 2011 3:39 pm |   |
				| Hello,
 I've just started using CCS C after a four year hiatus.  The project I'm working on uses a PIC18F2550 to communicate, via USB, to a computer and act as i2c master to communication with two PIC16F1823 slave devices.  I have the software, firmware, and hardware figured out for the PIC18 but the PIC16's are causing me some problems.
 I've got a PIC16F1823 wired to a ICD-U40 and the oscillator frequency reads 500kHz regardless of what I do.  I've gone through the forum and other internet sites and nothing seems to make a difference.  Can anybody offer me help/insight based on the below code?
 I'm able to toggle outputs and write to RS232 without any issue (i2c isn't working but that is another issue, I think).
 I am using CCS v4.125 for compiler and my ICD-U40 firmware is 2.91.
 Header file
  	  | Code: |  	  | #include <16F1823.h> #device ICD=TRUE
 #device adc=16
 #FUSES INTRC_IO
 #FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
 #use delay(clock=16000000)
 #use rs232(baud=2400, xmit=PIN_C3, rcv=PIN_C4)
 #use i2c(SLAVE,SLOW,sda=PIN_A4,scl=PIN_A5,ADDRESS=0xa0)
 *.c file
  	  | Code: |  	  | #include <TriggerController.h> #int_EXT
 void  EXT_isr(void)
 #int_SSP
 void  SSP_isr(void)
 printf("i2c\n");
 setup_oscillator(OSC_16MHZ|OSC_INTRC|OSC_PLL_OFF,0);
 //setup_oscillator(OSC_16MHZ|OSC_NORMAL,0);
 enable_interrupts(INT_EXT);
 enable_interrupts(INT_SSP);
 printf("Hello\n");
 //TODO: User Code
 output_high(PIN_C5);
 delay_ms(10);
 output_low(PIN_C5);
 delay_ms(10);
 Eric
		| PCM programmer
				|  Posted: Wed Nov 23, 2011 5:22 pm |   |
				| I tested the program below with vs. 4.125 in hardware, and it blinks the LED at a 1 Hz rate.  I programmed it with a Microchip ICD3.  It's running
 on a Microchip "Low Pin Count" board.
 #fuses INTRC_IO, NOWDT, BROWNOUT, PUT, MCLR
 #use delay(clock=16M)
 output_toggle(PIN_C0);
 I don't think you should depend upon CCS ICD-U40, etc., to report the
 correct device frequency.  Many people say that it doesn't do it correctly:
 http://www.ccsinfo.com/forum/viewtopic.php?t=38312&start=2
 http://www.ccsinfo.com/forum/viewtopic.php?t=44454&start=3
 Just blink an LED to prove that it's running at the correct frequency.
		| peer9802
				|  Posted: Wed Nov 23, 2011 5:31 pm |   |
				| OK.  I was measuring "blink times" using an o-scope and everything looked fine besides the ICD value.  I will ignore it for now.  On to other issues... _________________
 Eric
 | You cannot post new topics in this forum You cannot reply to topics in this forum
