No return from function, why?
eabir
PostPosted: Wed Nov 16, 2011 10:01 am     Reply with quote
Why do the Visual_on () function is endless and dont return to main after finish the 'for' loop ?
#include <10F222.h>
#device adc=8
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES NOMCLR                     //Master Clear pin: disable
#FUSES NOPROTECT                  //Code protected from reads
#FUSES NOMCPU                      //No Watch Dog Timer
#FUSES IOSC4
#use delay(Clock=4MHZ,OSC)
 //      #use delay(clock=40)         // Only for Debug Mode
 //     #use delay(clock=1000000)         // Only for Debug Mode
#bit OSCCAL_0 = 0x05.0           // Disable OSC on GP2, Enable as I/O
// Configuration bits:
//   1.MCPU = Pull up disabled
//  2.WDT = disabled
//  3.MCLRE = I/O & tied to VDD
  Sound_on (void)
      int8 step = 0;
      for(step = 0;step < 1 ;step++ ){  //
        //   cnt0 = 0;
          output_low(PIN_B1); // Play sound
  Visual_on (void)
      int16 step = 0;
      for(step = 0;step < 1 ;step++ ){  //  Loop control
           output_low(PIN_B2); // Sound sequence
           delay_ms(100); //6Khz     was 73??
      return:
   int8 step;
   int8 temp_val;
   int8 val_ref_lo = 0;
   int8 val_ref_hi = 0;
   int8 Val = 0;
   int8 avalue;
   int8 value;
   int8 cnt0 = 0; // counter
   OSCCAL_0 = 0;         //set bit 0 in reg 5 to zero.
   setup_adc_ports(sAN0);
   setup_adc(ADC_CLOCK_DIV_4);
   setup_adc( ADC_ON );
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1|DISABLE_PULLUPS); //|DISABLE_PULLUPS
   setup_wdt(WDT_2304MS);
  //   output_low(PIN_B2);
      output_high(PIN_B2);
set_adc_channel(0);
delay_ms( 20000 );       //wait
temp_val = read_adc(); // first reference adc read
while (1)  {
output_high(PIN_B1); //
//output_low(PIN_B2); //
output_high(PIN_B2); //
         value = read_adc();
           delay_us(100);
            avalue = read_adc();
            delay_us(100);
             val_ref_lo = temp_val - 1;
         val_ref_hi = temp_val + 1;
         Val = value -avalue;
       if (((avalue <= val_ref_lo) || (val_ref_hi <= avalue)) && (Val < 2))
         cnt0 = 1;
         delay_ms( 4000 );
         if (cnt0 == 1 && Val < 1)
// Activate  //
          delay_ms( 100);
           Visual_on (); //
                  Sound_on (); //
   //   output_low(PIN_B2); //
Geps
PostPosted: Wed Nov 16, 2011 10:03 am     Reply with quote
Semi colon _after_ the return help?
PostPosted: Wed Nov 16, 2011 8:32 pm     Reply with quote
How about you explain what YOU WANT visual_on and
sound_on to do --- and why any loop is required.
And then also mention HOW Many times you think
the loops are executed in each ??
eabir
PostPosted: Thu Nov 17, 2011 12:55 am     Reply with quote
I tried return(0), no help.
Even if there is no loop in the visual_on(), the function dont return to main.
FvM
PostPosted: Thu Nov 17, 2011 1:24 am     Reply with quote
Do you actually see it's not returning? How? Or is it only a conclusion?
eabir
HW problem
PostPosted: Thu Nov 17, 2011 2:43 am     Reply with quote
guys,
thank you all, but its a hardware problem of the I/O ports, (after checked with ICE)
PostPosted: Thu Nov 17, 2011 6:09 am     Reply with quote
It'd be interesting to see the listing to see how the compiler codes.....
RF_Developer
PostPosted: Thu Nov 17, 2011 6:29 am     Reply with quote
Probably it'd code it just like any other for loop on an int loop variable. I doubt the compiler/optimiser is clever enough to realise the inner loop code is 'Allo 'Allo code (i.e. will execute only once), and that the loop test/increment can be optimised away.
RF D.
