Jody
| AtoI going wrong only for 'D'??? |
Posted: Wed Nov 16, 2011 7:38 am |
compiler version 4.119
Pic: 18F8722
What I have:
eeprom_data1[0] = string[i];
eeprom_data1[1] = 0x0D;
data1 = atoi(eeprom_data1); //first byte
string I filled with: "D"
and after the atoi data1 is 0...??
When I do this with A or B or 9 or whatever things do like I want.
What am I doing wrong???
Regards,
Jody |
SherpaDoug
Posted: Wed Nov 16, 2011 8:07 am |
I would have expected atoi() of 9, A, B, or D to return zero. As printed none of them represent a number.
Just what were you expecting the numerical value of carriage return to be? _________________ The search for better is endless. Instead simply find very good and get the job done. |
Jody
Posted: Wed Nov 16, 2011 8:21 am |
I thought that for a AtoI function the string has to be ended with a 0x0d.
And I expected the integer value of the value from the string... |
Posted: Wed Nov 16, 2011 8:47 am |
Manual - Quote:
"ivalue = atoi(string)
string is a pointer to a null terminated string of characters."
_Null terminated_.
Second point, 1, does not equal '1'.
Third, to convert hex values, the string has to include the format characters to say 'hex value', otherwise how would it ever tell the difference between '11' decimal, and '11' hex?.
char string[10];
int i;
strcpy(string,"0x11");
x=atoi(string);
