Problem with clock pic16f1937
Lemosek
PostPosted: Sun Nov 13, 2011 10:27 am     Reply with quote
I have problem with clock at pic 16f1937. I have connected crystal 8MHz and two capacitors 18p. Code at pic:
#include <16F1937.h>
#device *=16
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT, NOVCAP
#use delay(clock=32M)
#use rs232(baud=9600, UART1, stream=PC, ERRORS)
and in main loop
         LED1ON
        LED1OFF;
        printf("Test");
When I put #use delay(clock=8M) like connected crystal, pic is faster, only work correctly when i have #use delay(clock=32M).
What I doing wrong? I don't set PLL but clock is 4x8MHz.
Best regards
PostPosted: Sun Nov 13, 2011 10:54 am     Reply with quote
Compiler version???
Try with:
#device *=16
#use delay(crystal=8M, clock=8M)
and in main:
   setup_oscillator(OSC_NORMAL);
Have a memory of some compiler versions setting the PLL by default. This makes sure it is turned off....
Lemosek
PostPosted: Sun Nov 13, 2011 12:38 pm     Reply with quote
My compiler is: 4.120.
I tried Your code but nothing change.
Where I find this option about pll, I use default IDE from CCS.
best regards
PostPosted: Sun Nov 13, 2011 3:34 pm     Reply with quote
How are you writing this to the chip?.
I tested with this setup code, and running a basic flash for one second routine, it works correctly with your compiler version.
If you are running through the debugger though, the PLL won't change till the chip is reset. Or if you are using a bootloader, these (generally) won't change the PLL.
Lemosek
PostPosted: Sun Nov 13, 2011 3:54 pm     Reply with quote
I compiled my code in IDE and load hex file by pickit2 in to pic.
Can you do it test with rs232. Send something with #use delay(clock=8M) and #use delay(clock=32M). Because in my circuit it work correctly only #use delay(clock=32M).
Best regard
PostPosted: Tue Nov 15, 2011 1:34 pm     Reply with quote
Disable the PLL by adding the #fuse shown below:
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT, NOVCAP,PLL_SW
Lemosek
PostPosted: Tue Nov 15, 2011 1:48 pm     Reply with quote
Hello, dear PCM programmer thank You so much now is ok. Everything works correct.
P.S.
In the manual ccs I can't find this fuse.
best regards
PostPosted: Tue Nov 15, 2011 2:03 pm     Reply with quote
Look at the top of the 16F1937.h file to find the list of available fuses.
Lemosek
PostPosted: Tue Nov 15, 2011 3:18 pm     Reply with quote
Thank You one more time. I'm the beginner in ccs.
Best regards
