mcn
| SD card write use by elm chan library or anyway? |
Posted: Fri Oct 07, 2011 2:00 am |
hi all,
My microcontroller is pic18f452.
I want to write GPS data to SD card. I read to GPS data, there isn't problem read gps data. But how can i write GPS datas to SD card.
Everybody says use to elm chan library. I look this library but this is soo complex.
http://elm-chan.org/fsw/ff/00index_e.html
How can i use to elm chan lib. Or i can use to other library, it's not different.
Thanks. |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
Posted: Fri Oct 07, 2011 2:26 am |
I sell an implementation of the elm library that has been ported to CCS. It comes with the full source for two sample applications including a real time data logger application with a DOS like command line demonstrating the use of the library.
Note however this is a full file system. You would use this if you wanted to exchange files between Windows (or other FAT based file systems) with a PIC.
I forgot to add, a possible better choice of PIC to use for file system type data loggers would be the PIC18F4620. It is pin compatible to the PIC18F452 but has more RAM making it better suited to supporting files systems for data acquisition, processing and logging applications. _________________ Regards, Andrew
mcn
Posted: Fri Oct 07, 2011 3:14 am |
Thanks asmallri,
But I just write opened .txt files sd card. And your price is soo much expensive for me  |
mcn
Posted: Fri Oct 14, 2011 6:47 am |
Hello again,
so, I am using this library now.
http://read.pudn.com/downloads97/sourcecode/embed/397863/SD_MMC/HDD%20Driver.c__.htm
and my code is here:
#include <18F452.h>
#FUSES HS
#FUSES BORV20 //Brownout reset at 2.0V
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,parity=N,stop=1,ERRORS)
#use fast_io(a)
#use fast_io(c)
#define led pin_a0
#include <stdlib.h>
#include "hdd.c"
char ch;
char receive[250];
int receiveLength=0;
int k=0;
int j=0;
int x;
char ch2;
int8 uydu;
int8 rec2[100];
int reclen=0;
char data[]={"86"};
char timest[9];
char boylamst[9];
float time,boylam;
int r1,error,error0,error1;
int16 rec_no;
int16 index,rec_size;
int32 offset;
char fname[32],buff0[MMC_BUFF_SIZE+1],buff1[MMC_BUFF_SIZE+1];
char c;
void kart_init()
///////// init MMC ////////////////////////////////////////
error=init_MMC(1000);
if (error>0) {
output_high(pin_b5);
//goto mmc_exit;
output_high(pin_b6);
output_low(pin_b6);
printf("\n\r MMC initialized \n\r");
rec_size=MMC_BUFF_SIZE;
//strcpy(fname,"HOME\\HOME.TXT");
strcpy(fname,"erb.txt");
error0=open_file(0,fname,rec_size);
//Dosyayı burda açıyor
if (error0>0) {
printf("\n\r fopen as 0 failed error=%U\n\r",error);
//goto mmc_exit;
else printf("\n\r opened as 0 file %s with rec size %lu \n\r",fname,rec_size);
output_low(pin_b6);
void serilasyon()
while(true)
ch=getchar();
receive[receiveLength]=ch;
receiveLength++;
if(ch=='C')
break;}
while(true)
ch2=getchar();
rec2[reclen]=ch2;
reclen++;
if(ch2=='$')
{break;}
// if(reclen==100)
// {break;}
reclen=0;
receiveLength=0;
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
disable_interrupts(global);
disable_interrupts(int_rda);
set_tris_a(0x00);
set_tris_c(0b10010011); //c7=rx I, c6=tx O, c5 SDO O,c4 SDI I
output_a(0x00);
printf("\r\n**** GPS LOGGER **** ");
printf("\r\n");
Delay_ms(1000);
printf("\r\Now initializing SD kart ");
printf("\r\n");
Delay_ms(3000);
SETUP_SPI (SPI_MASTER | SPI_SS_DISABLED |SPI_H_TO_L| SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H);
buff0[MMC_BUFF_SIZE]=0;
buff1[MMC_BUFF_SIZE]=0;
rec_no=0;
kart_init();
output_toggle(led);
serilasyon();
printf("Timet:%c ",timest);
for(j=0;j<9;j++)
timest[j]=rec2[j+1];
time=atof(timest);
printf("\r\n%f",time);
error0=file_write(0,timest);
I want to write to SD card time from the GPS.I read the GPS data and i cap the time.but my problem is write to sd card.
i create the text file when SD card is connecting to computer.text file name is "erb.txt".When SD card connecting to my circuit,pic read to gps data,and sending time to serial port and write SD card.
But when i open to erb.txt on the computer,i see pic18f452 write to just last time. (for ex: 152358.02)Circuit is repeatedly write on the last data.And i just see last time data when i open the erb.txt at the computer.
I want to write all time data to sd card.
How can i solve this problem?
My connecting diagram like this:
Uploaded with ImageShack.us
[/img] |
Joined: 01 Jul 2010 Posts: 9638 Location: Greensville,Ontario
Posted: Fri Oct 14, 2011 7:09 am |
Couple of problems...
1) usually the LF series of PICs are good for 3 volt operation, so is the 18F452 you're using rated for 3 volt operation? Be sure to read the Dc characteristics section....
2) In your main program, you never attempt to write to the SD card..
3) If this is just a Proteus simulation you MUST tell us ! The schematic has several errors,so if real hardware is wired up exactly as dhown, it'll never work!
4) You've got a real mess of code 'bits' with no knowledge that they work. Perhaps where you got the library from has working test code ? |
mcn
Posted: Fri Oct 14, 2011 7:52 am |
temronic;
i use the 3.4 volt for pic,gps and max232.And working all.
write comute is here in the while of my code: "error0=file_write(0,timest); "
This schematic is just show.I create the real circuit and i try the real.I don't use proteus and simulation.
I got this code were library from.
[/b] |
mcn
Posted: Sun Oct 23, 2011 1:59 pm |
my problem is continue
How can i solve this problem? |
asmallri
Posted: Sun Oct 23, 2011 6:35 pm |
Your schematic says you are running the PIC with a 10MHz crystal but your code implies 20MHz. A standard PIC18F will not run reliably at 3.4 volts at 20MHz. A 20deg C it may run, at 22 deg c it may not run. It might run on a Wednesday, but not on a Thursday etc.
There is nowhere in your code when you close the file or flush the file system buffers. If you remove a card without the file system being synchronized then data and control structures could be (and likely would be) still sitting in RAM. Removing the card prematurely can corrupt the file system on the card.
This is the same for any product implementing a FAT file system. It is why camera manufactures tell you not to remove a card that may be being written to. It is the same reason you should use device manager when removing USB flash drives from PC's and other devices. _________________ Regards, Andrew
mcn
Posted: Mon Oct 24, 2011 12:45 am |
asmallri;
I use to 20 mhz crystal on my circuit.
I understand voltage problem.
And looking my library and i can't find "close file" code?
How can i do that? |
asmallri
Posted: Mon Oct 24, 2011 12:58 am |
| mcn wrote: | asmallri;
Get yourself a decent library. _________________ Regards, Andrew
mcn
Posted: Mon Oct 24, 2011 1:14 am |
I understood asmallri,
Well, where can I get decent library? |
asmallri
Posted: Mon Oct 24, 2011 1:29 am |
| mcn wrote: | I understood asmallri,
See my first post in this thread. _________________ Regards, Andrew
mcn
Posted: Mon Oct 24, 2011 1:33 am |
| I know,but this cost expensive for me... |
Posted: Mon Oct 24, 2011 7:55 am |
| mcn wrote: | temronic;
i use the 3.4 volt for pic,gps and max232.And working all. | Running the PIC at lower than specified voltages is tricky, especially at the higher frequencies. So why run it at a high 20MHz when 10MHz would suffice? I think you are taking unnecessary risks.
| Code: | | SETUP_SPI (SPI_MASTER | SPI_SS_DISABLED |SPI_H_TO_L| SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H); | I'm surprised your SD card is doing anything as this configuration is invalid. SPI_SS_DISABLED is a slave parameter and should never be used for a SPI master. Change to: | Code: | | SETUP_SPI (SPI_MASTER | SPI_H_TO_L| SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H); | or, even better: | Code: | #define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
SETUP_SPI (SPI_MASTER | SPI_MODE_3 | SPI_CLK_DIV_16); |
Nice find, but this is a driver with hardly any references in Google so it will be hard to find support for it. The original posting is from 2004 with the mentioning that the code is not finished and the original website is gone. Maybe not such a good choice for your project.
The cause for your file only showing the latest data has to do with the used SD library. The file_write function is strange and difficult to use. I don't understand all details but it looks like you have to specify the maximum file size in the file_open() function and then the file_write() only does an update of the entire file. So it is up to your program to collect all data in an internal buffer and write the whole file at once. Not an ideal solution. You could modify the SD library but seems to me like a waste of time to revive an old unused library.
You were asking for other SD libraries:
- Andrew's library is known to work and can be used directly with the CCS compiler. However,quality comes at a price, it is not free.
- ELM that you have found is also good, but as fas as I know no-one ever put in the effort to port it to CCS. A lot of work and quiet large for the small PIC memory.
- CCS offers a simple FAT32 library. Easy to use and free, but contains some bugs in formatting the card. Workarounds have been posted in this forum but requires some Googling to find the threads.
- The Code Library of this forum contains at least two FAT32 drivers. This might be your best bet because the code is actively supported by the users of this forum. |
