NaN Check
sei500510
NaN Check
PostPosted: Wed Oct 19, 2011 7:49 am     Reply with quote
hi,
how to check if float number is NAN?
IF (n != n)
don't work. Sad
VC
Gabriel
PostPosted: Wed Oct 19, 2011 8:05 am     Reply with quote
IF (n != n)
that reads "if this value is not equal to the same value"
that is impossible... the value cant be 2 values at the same time.
in other words:
IF(1 Not equal to 1)
this will always fail as 1 is always equal to 1.
... you should better explain what you are trying to do.
g
CCS PCM 5.078 & CCS PCH 5.093
sei500510
PostPosted: Wed Oct 19, 2011 8:55 am     Reply with quote
Thanks Gabriel
if you look here:
http://en.wikipedia.org/wiki/NaN
you will find the example of code, but this trick don't work in CCS.
I want to read a floating number stored in eeprom. The first time, all the cells of eeprom contain 0xFF so the read_float_eeprom() return NAN
VC
Gabriel
PostPosted: Wed Oct 19, 2011 9:39 am     Reply with quote
Then... you could define a range of "Valid" numbers, and if the number you read falls in this range its valid, else NAN.
Then again... 0xFF is a "valid" number (max 8 bit reading of ADC) so its still unclear what you are trying to do.
You want to know if the EEprom contains "real" data or if is still in its reset (0xff) state. Is this correct?
If so... unless 0xff is not a posible value in your stored data, then i do not see a way to determine this by just reading the value.
g.
PostPosted: Wed Oct 19, 2011 4:16 pm     Reply with quote
This thread has a discussion of methods to recognize if the eeprom data is
all equal to 0xFF:
http://www.ccsinfo.com/forum/viewtopic.php?t=40718
