step mode vs adc
Goto page 1, 2, 3  Next
sahu77
step mode vs adc
PostPosted: Mon Sep 26, 2011 12:06 pm     Reply with quote
i am facing some problem about scening adc in step mode ... adc sens tabol as below ...
     O\P        ADC      RELAY POSITION ( 0=OFF  1=ON )
                            RL1 RL2 RL3       step_mode
   200 - 240   565 - 722     0   0   0   --   Step 0
   200 - 240   731 - 877     0   0   1   --   Step 1
   200 - 240   596 - 720     1   0   0   --   Step 2
   200 - 240   731 - 877     1   0   1   --   Step 3
   200 - 240   586 - 720     1   1   0   --   Step 4
   200 - 240   724 - 877     1   1   1   --   Step 5
and ccs c as below...
 switch (step_mode)
      // Step 0 -- ADC 565 - 722
        case 0:
          // Low Voltage protection is done here
            if ((ch<565) && ((input(SW2)==0) || (QuickStart_flag == 1)))
               return(LOW_VOLTAGE);
             if (ch < 722)//95 volt
               output_low(RL1);
               output_low(RL2);
               output_low(RL3);
             if (ch >= 722)  //115 v
            step_mode = 1;  // goto step 1
      // Step 1 -- ADC 731 - 877
        case 1:
           if (ch < 731) //now  case 2 < 115v
               step_mode = 0;  // Callback to step 0
         if (ch < 877)  //  < 137v
            output_low(RL1);
            output_low(RL2);
            output_high(RL3);
             if (ch >= 877)    // > 137v to 170 v
            // Switch to Step 2
            output_high(RL1);
            output_low(RL2);
            output_low(RL3);
           if (ch >= 720)  //115 v
            step_mode = 2;  // goto step 1
      // Step 2 -- ADC 596 - 720
        case 2:
           if (ch < 596) //now  case 2 < 115v
               step_mode = 1;  // Callback to step 1
         if (ch >= 720)
            // Switch to Step 3
            output_high(RL1);
            output_low(RL2);
            output_high(RL3);
               if (ch >= 877)  //115 v
            step_mode = 3;  // goto step 1
      // Step 3 -- ADC 731 - 877
      case 3:
         if (ch < 731)
            step_mode = 2;
         if (ch >= 877)
            // Switch to Step 4
            output_high(RL1);
            output_high(RL2);
            output_low(RL3);
            step_mode = 4;  // goto step 1
      // Step 4 -- ADC 586 - 720
      case 4:
         if (ch < 586)
            step_mode = 3;
         if (ch >= 720)
            // Switch to Step 5
            output_high(RL3);
            output_high(RL2);
            output_high(RL1);
            step_mode = 5;  // goto step 1
      // Step 5 -- ADC 724 - 877
      case 5:
         if (ch < 724)
            step_mode = 4;
         if (ch >= 877)
            // High Voltage protection is done here
               return(HIGH_VOLTAGE);
      //We have got here, so voltage should be normal
      return(NORMAL_VOLTAGE);
sahu
PostPosted: Mon Sep 26, 2011 12:10 pm     Reply with quote
there is just not enough to go on here about what you are trying to do
or what your actual problem IS .
try to be more clear and tell MUCH more about
what is supposed to be going on in your program
sahu77
PostPosted: Mon Sep 26, 2011 12:15 pm     Reply with quote
Actually I am trying to make mcu based stabilizer controlled card. It is based on 16f676.
I do not use linear adc i/p, because do some problem. So I decide I use step mode.
Sorry for my bad English.
sahu
PostPosted: Mon Sep 26, 2011 12:41 pm     Reply with quote
JUST FOR A START:
1- you don't say where var ch is loaded or how ( from ADC read??)
2- if you are using physical relays to change excitation and then measure
have you TIMED how long the relay contact open and close actually TAKE to happen - and allowed settling time for it all ?? ( hint open and close are usually NOT the same timing )
3- what do you MEAN precisely by step mode ADC?
you are still far from disclosing enough to get the help you want.
SherpaDoug
PostPosted: Mon Sep 26, 2011 12:46 pm     Reply with quote
I have been working with microcontrollers and robotics for nearly 30 years and I for one have no idea what "step mode" is. Is this a AC voltage stabilizer like a tapped transformer, or a mechanical part like an aircraft stabilizer?
What does your code do that it should not do, or not do that it should do?
sahu77
PostPosted: Mon Sep 26, 2011 12:58 pm     Reply with quote
"step mode" use for my understanding.
as you say ...AC voltage stabilizer like a tapped transformer I use for this.
For tapping changing I use relay.
I want post here my stabilizer + relay wiring schematic but can't understand how do it.
pls help me
sahu
PostPosted: Mon Sep 26, 2011 1:50 pm     Reply with quote
I will note ONE thing:
You are changing the value of step_mode within the switch function being driven by step_mode.
I have always entertained a certain paranoia about that sort of thing, even though the BREAK statement should protect you.
I would choose to assign my new step_mode value to some temporary var and then OUTSIDE the switch construct - assign that TEMP value back to switch_var.
OR
Drive the switch argument with a copied VAR fo step_var.
It may not be required now but I got myself into trouble long ago by doing just the sort of thing you do here inside your switch statement.
sahu77
PostPosted: Mon Sep 26, 2011 1:56 pm     Reply with quote
asmboy wrote:
i will note ONE thing:
you are changing the value of step_mode within the switch function being driven by step_mode
i have always entertained a certain paranoia about that sort of thing, even tho the BREAK stmt should protect you
i would choose to assign my new step_mode value to some temporary var and then OUTSIDE the switch construct - assign that TEMP value back to switch_var
OR
drive the switch argument with a copied VAR fo step_var
it may not be required now but i got myself into trouble long ago by doing just the sort of thing you do here inside your switch statement
Where I post my stabilizer sch + wiring diagram ? Then everything is clear, what I am saying to everybody. Right now I am facing some language problem because my English is very bad.
sahu
SherpaDoug
PostPosted: Tue Sep 27, 2011 7:38 am     Reply with quote
Before worrying about the wiring I think we first need to know how your code is currently behaving. What does your code do that it should not do, or not do that it should do?
PostPosted: Tue Sep 27, 2011 8:10 am     Reply with quote
i can tell one thing for sure:
if these state changes apply to physical relays - this
and all your other relays state changes - is a BIG TROUBLE SPOT.
// Switch to Step 3
            output_high(RL1);
            output_low(RL2);
            output_high(RL3);
in my experience:
relays take more time to CLOSE than to OPEN.
so you could be having some short duration nasty , unintended
connections being made in "mains voltage land" by NOT considering
overlap timing of relay contacts.
PostPosted: Tue Sep 27, 2011 8:39 am     Reply with quote
Not to mention the EMI noise and transients caused by switching even moderate levels of power !
You could minimize it by using SSRs( triacs) with zero crossing but switching AC power of say a few watts spells a LOT of headaches !!
PostPosted: Tue Sep 27, 2011 12:53 pm     Reply with quote
Use a free image hosting website, such as http://www.imageshack.com
and then post a link to it here.
sahu77
PostPosted: Thu Sep 29, 2011 2:15 pm     Reply with quote
this link not work here (India).
sahu
sahu77
PostPosted: Sun Oct 16, 2011 2:11 am     Reply with quote
stabilizer sch + wiring diagram here
http://imageshack.us/photo/my-images/705/stb02.png/
http://imageshack.us/photo/my-images/705/90v300vstbwiring.png/
pl help me / / /
sahu
asmallri
PostPosted: Sun Oct 16, 2011 2:49 am     Reply with quote
asmboy wrote:
in my experience:
The [spam] is equally true. It often takes longer for a relay to open (as a result of the relay coil being de-energized) than for the contacts to close (when the relay coil is energized). There are lots of factors that contribute to this behaviour however one key consideration is the back EMF protection diode feeding current back into the relay coil as the relay's magnetic field collapses thereby prolonging the relay holding time.
Regards, Andrew
Page 1 of 3
