Tagge
| WDT on a PIC12F635 |
Posted: Tue Oct 11, 2011 5:57 am |
Hi, I'm having trouble to get the WDT to work on a 12F635. What am I doing wrong?
#FUSES WDT //WDT on
#FUSES PUT //Power Up Timer
#FUSES NOWURE //Wake-up and continue
#use delay(clock=31000, restart_wdt)
void init(void){
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
setup_wdt(WDT_2304MS);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
setup_oscillator(OSC_31KHZ);
then in main
while(1){
restart_wdt();
do my thing..
Where's the stupidity of mine?  |
Posted: Tue Oct 11, 2011 7:03 am |
It might help if you told us what is wrong....
However, key thing with most of the smaller PIC's, is that parts of the prescaler are _shared_ between Timer0, and the WDT. So changing one affects the other. So selecting WDT_2304MS, will set the RTCC prescaler to RTCC_DIV_256. Use the watchdog _postscaler_ instead, which can be independently set.
Tagge
Posted: Tue Oct 11, 2011 7:58 am |
Thanks, its just the problem.. you nailed it exactly. It seems that the timer 0 is depending on the WDT scaler.
This seems to get it working better.
void init(void){
setup_wdt(WDT_18MS|WDT_TIMES_1);
setup_vref(FALSE);
output_low(air_valve);//renblÄsning off
output_high(air_led);
/Tagge |
