Tactile Button PIC18F46K22
scuba
PostPosted: Mon Oct 10, 2011 4:18 pm     Reply with quote
Hi there,
I have a PIC18F46K22 and i want to activate the interrupts by pressing a tactile button. The problem that is the interrupt doesn't work and i don't know how to solve it.
#FUSES NOPLLEN,NOWDT, NOLVP, HS
int current=0;
#INT_RB
void rb_isr() {
   //current=input_b();
   current=input(PIN_B4);
   fputs("Bottom", hostPC);
   if(!current){
      output_high(PIN_A0);
      fputs("Button", hostPC);
      output_high(PIN_A1);
void main(){
   enable_interrupts(INT_RB);
Thank you!
PostPosted: Mon Oct 10, 2011 4:28 pm     Reply with quote
Just for starters
DO NOT DO any serial transmission within the int handler.
Set a variable or use the state of the pin YOU changed
to signal the MAIN() as to what you want to send to the host.
If your pic interrupts on both state changes hi/lo -- lo/hi.
THEN TEST which STATE YOU ARE IN AND SAY ONLY FLAG
the release and act accordingly.
PostPosted: Mon Oct 10, 2011 4:36 pm     Reply with quote
Read this thread. It's possible that your compiler version has bugs with
the 18F46K22. This thread has code to make #int_rb work with that PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=45032
PostPosted: Mon Oct 10, 2011 5:16 pm     Reply with quote
ALSO
that 1 second delay in the ISR is the KISS of DEATH
to anything else you might put in MAIN()
the rule of ALL good INT handlers is:
GET in and out FAST
no delays
no serial comm
PostPosted: Tue Oct 11, 2011 1:51 am     Reply with quote
Also, the other glaring thing, is that the chip will have gone to sleep. Potentially should wake up, but no guarantees.
You need to have something at the end of main, to stop the code dropping off the end.
scuba
PostPosted: Tue Oct 11, 2011 7:46 pm     Reply with quote
following your suggestions i programmed this code but the button doesn't work too. Is that the problem may be hardware or still bug?
Thank you all.
#INT_RB
void rb_isr() {
   fputs("Hi", hostPC);
void main(){
PostPosted: Tue Oct 11, 2011 9:00 pm     Reply with quote
Why not try the code in the link that I gave you ?
The program is at the end of this thread:
ezflyr
PostPosted: Tue Oct 11, 2011 9:04 pm     Reply with quote
Actually, you haven't implemented a single suggestion from the respondents to your query!
As asmboy said, no serial ops inside the ISR. This means get rid of the puts statement.
As pcm programmer said, your version of the compiler might have a bug, and you might need to manually configure the chip. Where is that code?
As Ttelmah said, you need to insert some code at the bottom of main to keep the code from reaching the default 'sleep' instruction put in by the compiler. A 'while(1){}' works nicely!
Other than that, you got everything ;-)!
I'd take a step back a bit and try a much simpler task like blinking an LED. Can you do that? Once that is done, you can use the LED for diagnostics in place of the serial ops in your ISR.
John
scuba
PostPosted: Wed Oct 12, 2011 1:01 pm     Reply with quote
Problem Solved!
Thank you PCM Programmer, you're right.
