PIC18f4550 does not wake up from sleep
Prefekt
PostPosted: Thu Sep 29, 2011 2:13 pm     Reply with quote
My PIC is sleeping after the sleep() command. But I can't wake up the pic?
I have from the ex_wakeup.c this:
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
On which pins will the pic wake up?
Anybody an Idea?
Best regards
Volker
PostPosted: Thu Sep 29, 2011 2:25 pm     Reply with quote
Look at section 3.3 in the datasheet titled SLEEP MODE and section 9.7 about interrupts.
Also, see Section 10.2 near the bottom of the first column.
Prefekt
PostPosted: Sat Oct 01, 2011 5:59 am     Reply with quote
the ex_wakeup works fine.
But I my appliction the pic does not wake up. I USB the USB connection from the ex_usb_serial.c example and enable INT_EXT and GLOBAL interrupts.
On the pin B0 is a push button from +5V and a pull down resistor...
Best regards
Volker
PostPosted: Sat Oct 01, 2011 6:21 am     Reply with quote
Post your CCS compiler version and a short, complete, compilable program that shows the problem.
PostPosted: Sat Oct 01, 2011 3:02 pm     Reply with quote
Seriously, you can't do this.....
If your device is connected to a USB bus, then you can't just put it to sleep. Doing so, risks putting the USB bus into an unpredictable state. The USB controller itself, should only be put to sleep, when an IDLEIF is received from the USB host. Otherwise, you need to leave the USB component powered (you can sleep the CPU itself). A device connected to the USB bus, _must_ respond when the master talks to it. It you completely sleep the CPU, this won't happen....
You can use sleep(SLEEP_IDLE), to leave the USB components powered.
