championx
| AUTOMOTIVE CAN BUS |
Posted: Tue Dec 28, 2010 2:00 pm |
Hi! before I say anything, sorry for my english!
Well, I'm making an automotive CAN BUS data logger, I have two boards that can "talk" to each other on can bus at 250 kbps and 500 kbps.
The question is, if I connect one of these boards to the CAN BUS port of a car, I should be able to "look" at the information present on the bus, like RPM, SPEED, etc??
I also have to do this on a truck... I think that the protocol is j1939 right?
thanks! |
ezflyr
Posted: Tue Dec 28, 2010 2:17 pm |
Coincidentally, I saw a similar project today for the Arduino. There seems to be a lot of information there about the CAN bus interface, and reading the data you mention.
http://code.google.com/p/opengauge/wiki/OBDuino
Good luck!
John |
collink
| Re: AUTOMOTIVE CAN BUS |
Posted: Wed Dec 29, 2010 6:29 am |
| championx wrote: |
Not exactly... the OBDuino project shows this. Basically you have to ask for the info you want to receive through the use of PID codes. If you hook your device up and send the PID code in the proper format then you should get a reply back with the info you requested.
This link to wikipedia has a lot of helpful info that will get you started:
http://en.wikipedia.org/wiki/OBD-II_PIDs
| Quote: |
thanks! |
Yeah, that's a popular protocol on trucks (and, to some extent, on electric vehicles too.) |
championx
Posted: Wed Dec 29, 2010 6:50 am |
Ok thanks! But, i dont understand something. If the bus is sending information all the time to other ECUs, why i cant hook up and "see" all the data like in a j1708 bus?
I know i have to query some PIDs because they are not transmited all the time. But, RPM, speed, etc should be transmited, right?
thanks! |
collink
Posted: Wed Dec 29, 2010 7:12 am |
| championx wrote: | Ok thanks! But, i dont understand something. If the bus is sending information all the time to other ECUs, why i cant hook up and "see" all the data like in a j1708 bus?
thanks! |
It's possible. You should hook up to the OBDII port and listen in to see what is going on. However, there could be multiple buses in the car and it's likely that critical ECU functions are on a different bus that you can't see. |
Posted: Wed Dec 29, 2010 10:56 am |
Spot on.
Depends what you want to see. On my current car, the main ECU functions are on a fibre optic bus, as are the ABS stuff. However the basic 'engine revs, temperature, battery condition, etc.', are on the Can bus, going to the instrument panel. There are three CAN busses & two fibre optic links.
Geps
Posted: Tue Sep 27, 2011 5:56 am |
| Ttelmah wrote: | Spot on.
Interesting....Out of interest which car is this? I've only heard of fibre optic being used in MOST bus - not between safety critical systems. |
