kbd.c and lcd.c at the same time on port B pic16F877
gardiatech
PostPosted: Tue Sep 20, 2011 8:30 pm     Reply with quote
hi
I'm new using ccs, it's great
but i have a problem and i need some expert help.
I'm trying to use port_b to drive lcd (4 bits data bus) and 4x3 keypad on rb interrupt, actually lcd it is working, but when a key is pressed, i use k=kbd_getc() inside rb_isr and i try to show on lcd and nothing happens.....
Searching i found a library to handle 4x4 keypad and i tried with this keypad library and works, it shows the key pressed on Proteus, but a logic collision happen......
circuit
This is the code using kbd.c
static char c;
unsigned char k;   //Variable global tecla
//#include <keypad.c>
#include <kbd.c>
#define LCD_ENABLE_PIN PIN_A0
#define LCD_RS_PIN PIN_A1
#define LCD_RW_PIN PIN_A2
#define LCD_DATA4       PIN_B0
#define LCD_DATA5       PIN_B1
#define LCD_DATA6       PIN_B2                                    ////
#define LCD_DATA7       PIN_B3
#define LCD_DATA_PORT 0x06
#define LCD_TYPE 2
#define LCD_TRIS_LOCATION 0x86
#include <lcd.c>
#define use_portb_kbd TRUE
#byte PORTB=0x06
   port_b_pullups(TRUE);
   SET_TRIS_B( 0xF0 );
   #asm movf 0x06,0 #endasm //evita interrupcion a la entrada.
   clear_interrupt(int_RB);
   enable_interrupts(INT_RB);
   lcd_init();
   kbd_init();
   // TODO: USER CODE!!
   lcd_putc("Ready...");
//RUTINA DE INTERRUPCION DEL PUERTO B
#int_RB
void RB_isr()
   disable_interrupts(INT_RB);
   delay_ms (100);
   #asm movf 0x06,0 #endasm   //Sin esta instruccion no se pone a cero bandera de interrupcion
// Put your code here.
   k=kbd_getc();
   lcd_putc(k);
   output_bit( PIN_C0, 1);//this it's just for see in proteus counter
   output_bit( PIN_C0, 0);
This is the lib that works on proteus but showing logic collision
////                             keypad.c                              ////
////                  Driver para teclado 4x4 generico                 ////
////  init_keypad()   Debe llamarse desde el programa principal        ////
////                  antes de cualquier funcion                       ////
////  scan_keypad()   Función de escaneo de teclado segun             ////
////              la matriz de teclado                         ////
////  read_keypad()     Encuentra la tecla por el metodo de inversion    ////
////              de puerto, espera a que se deje de pulsar y      ////
////              retorna.                                 ////
////         RB4 RB5 RB6 RB7                                 ////
////           |---|---|---|---|      El teclado se conecta sin      ////
////  RB0 ---> | 1 | 2 | 3 | A |      necesedad de resistencias ya   ////
////           |---|---|---|---|      que tiene las resistencias de  ////
////  RB1 ---> | 4 | 5 | 6 | B |      pull-up activadas             ////
////  RB1 ---> | 7 | 8 | 9 | C |                              ////
////  RB3 ---> | * | 0 | # | D |                              ////
//Direcciones de los registros segun PDF del pic 16fXXX
#byte PORTB=0x06   //Pic 16f877a
#byte TRISB=0x86   //
void init_keypad()
   port_b_pullups (TRUE);    //Habilita pull-up internos del puerto B
   TRISB=0xF0;
   PORTB=0;
   enable_interrupts(INT_RB);      // Habilita la interrupcion del puerto B ( RB4 - RB7).
   enable_interrupts(GLOBAL);      // Habilita las interrupciones globales.
unsigned char scan_keypad()
   unsigned char i=0,j=0,PORT,PORTH,PORTL,PH,PL,key;
   //Matriz de teclado
   char keypad[4][4] =   { {'1','2','3','A'},
                       {'4','5','6','B'},
                      {'7','8','9','C'},
                      {'E','0','F','D'} };
   PORT=PORTB;
   PORTH=PORT&0xF0;
   PORTL=PORT&0x0F;
   for(j=0;j<4;j++)
      PH=~(0b00010000<<j)&0xF0;
      if(PORTH == PH)
         for(i=0;i<4;i++)
            PL=~(0b00000001<<i)&0x0F;
            if(PORTL == PL)
               key=keypad[i][j];
               while(PORT==PORTB);
   if(key)
      return(key);   //Si la tecla es encontrada retorna valor segun la matriz de teclado
      return('/');   //Si la tecla no es encontrada retorna un caracter nulo
unsigned char read_keypad()
   char read,key;
   read=PORTB;
 //  TRISB=0x0F;
   PORTB=read;
 //  TRISB=0xF0;
   key=scan_keypad();
   return(key);
Could somebody help me?
Crying or Very sad Crying or Very sad
PostPosted: Tue Sep 20, 2011 8:52 pm     Reply with quote
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=26229&start=2
It explains how to put both the lcd and keypad on PortB, by using the
CCS driver files, lcd.c and kbd.c.
