where is mistake? (sleep and usb)(SOLVED)
respected
PostPosted: Mon Sep 19, 2011 8:25 am     Reply with quote
my code is:
led is blinking. (4 sec)
but usb 1 times enumerated. Last led blink usb is not enumerated.
compiler version 4.119
thanks.
#include <18F14K50.h>
#fuses HS,NOWDT,NOLVP,NODEBUG,CPUDIV4,NOMCLR,NOPUT,NOBROWNOUT,USBDIV1
#use delay(clock=12000000)
#define USB_CONFIG_HID_TX_SIZE   8
#define USB_CONFIG_HID_RX_SIZE   8
#include <pic18_usb.h>
#include <usb_log_hid.h>
#include <usb.c>
#define led1 PIN_C3
#define usb_sense PIN_C1
int8 ticks=0;
int8 usbstate=0;
int8 x;
int8 in_data[8];
#int_TIMER1
void timer1_isr()
void usb_debug_task(void)
   int8 new_connected;
   int8 new_enumerated;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   if (new_enumerated)  output_high(led1);
   else    output_low(led1);
   setup_timer_1(T1_EXTERNAL| T1_DIV_BY_1 | T1_CLK_OUT);
   set_timer1(0);
   usb_init_cs();
   in_data[0]=0;
   while (TRUE)
  ticks=0;
  output_high(pin_c3);
  delay_ms(50);
  output_low(pin_c3);
if(input(usb_sense)) usbstate=1;
else usbstate=0;
switch(usbstate)
case 1:  usb_task();
         usb_debug_task();
            if (usb_enumerated())
             if (usb_kbhit(1))
                  usb_get_packet(1, in_data, 8);
               x= in_data[0];
case 0:do {     sleep();
               delay_cycles(1); //Instruction pre-fetched - NOP
               clear_interrupt(INT_TIMER1);
               } while(++ticks<2);  //4
     }// switch
  }//while
}//main
PostPosted: Mon Sep 19, 2011 8:59 am     Reply with quote
Use the drivers....
#define USB_CON_SENSE_PIN PIN_C1 //Must be done before USB.C
#include <usb.c>
#define led1 PIN_C3
int8 ticks=0;
int8 x;
int8 in_data[8];
#int_TIMER1
void timer1_isr(void) {
void usb_debug_task(void) {
   int8 new_connected;
   if (new_enumerated)
      output_high(led1);
      output_low(led1);
void main(void) {
   set_timer1(0);
   usb_init_cs();
   in_data[0]=0;
   while (TRUE) {
      ticks=0;
      delay_ms(50);
      output_low(pin_c3);
      switch(USB_CABLE_IS_ATTACHED())  {
      case TRUE:
         usb_task();
         usb_debug_task();
         if (usb_enumerated()) {
             if (usb_kbhit(1)) {
                 x= in_data[0];
     case FALSE:
         do {
            sleep();
     }// switch
   }//while
}//main
Using usb_init_cs, _requires_ 'USB_CABLE_IS_ATTACHED' to be available as a macro, saying if the cable it present. It'll be defined for you automatically, if you define 'USB_CON_SENSE_PIN', but this needs to be done before you load usb.c. You have called the pin 'usb_sense' instead, and done it after loading usb.c, so the connection sense ability in the functions is basically turned off....
respected
PostPosted: Mon Sep 19, 2011 10:03 am     Reply with quote
#if defined(USB_CON_SENSE_PIN)
// #undef USB_CABLE_IS_ATTACHED
 #define USB_CABLE_IS_ATTACHED() input(USB_CON_SENSE_PIN)
#endif
usb.c file will be like this?
respected
PostPosted: Mon Sep 19, 2011 1:29 pm     Reply with quote
I did correction. But if the LED blinking coincides usb is working.
Also this correction file usb.h
mine connection
.....................4k7
VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
...............+---/\/\/\/\/\-----GND
................... 100k
actually connection
.....................100K
