koray_duran
| problem with modbus library |
Posted: Thu Sep 15, 2011 1:23 am |
I've trying to implement modbus slave example to my project. But even i am not successful to compile original codes. Nothing is modified in library.
Error is :
#byte TXSTA=getenv("sfr:TXSTA")
#bit TRMT=TXSTA.1
Undefined identifier
Expecting a (
Here is my codes :
#include <18F67J60.h>
#fuses HS, NOWDT, NOPROTECT
#use delay(clock=25M)
#define MODBUS_TYPE MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_RDA
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_BAUD 9600
#define MODBUS_SERIAL_RX_PIN PIN_C7 // Data receive pin
#define MODBUS_SERIAL_TX_PIN PIN_C6 // Data transmit pin
#include "modbus.c"
#define MODBUS_ADDRESS 0xF7
/*This function may come in handy for you since MODBUS uses MSB first.*/
int8 swap_bits(int8 c)
return ((c&1)?128:0)|((c&2)?64:0)|((c&4)?32:0)|((c&8)?16:0)|((c&16)?8:0)
|((c&32)?4:0)|((c&64)?2:0)|((c&128)?1:0);
int8 coils = 0b00000101;
int8 inputs = 0b00001001;
int16 hold_regs[] = {0x8800,0x7700,0x6600,0x5500,0x4400,0x3300,0x2200,0x1100};
int16 input_regs[] = {0x1100,0x2200,0x3300,0x4400,0x5500,0x6600,0x7700,0x8800};
int16 event_count = 0;
modbus_init();
while(!modbus_kbhit());
//check address against our address, 0 is broadcast
if((modbus_rx.address == MODBUS_ADDRESS) || modbus_rx.address == 0)
switch(modbus_rx.func)
case FUNC_READ_COILS: //read coils
case FUNC_READ_DISCRETE_INPUT: //read inputs
if(modbus_rx.data[0] || modbus_rx.data[2] ||
modbus_rx.data[1] >= 8 || modbus_rx.data[3]+modbus_rx.data[1] > 8)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
int8 data;
if(modbus_rx.func == FUNC_READ_COILS)
data = coils>>(modbus_rx.data[1]); //move to the starting coil
data = inputs>>(modbus_rx.data[1]); //move to the starting input
data = data & (0xFF>>(8-modbus_rx.data[3])); //0 out values after quantity
modbus_read_discrete_input_rsp(MODBUS_ADDRESS, 0x01, &data);
event_count++;
case FUNC_READ_HOLDING_REGISTERS:
case FUNC_READ_INPUT_REGISTERS:
if(modbus_rx.func == FUNC_READ_HOLDING_REGISTERS)
modbus_read_holding_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),hold_regs+modbus_rx.data[1]);
modbus_read_input_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),input_regs+modbus_rx.data[1]);
event_count++;
case FUNC_WRITE_SINGLE_COIL: //write coil
if(modbus_rx.data[0] || modbus_rx.data[3] || modbus_rx.data[1] > 8)
else if(modbus_rx.data[2] != 0xFF && modbus_rx.data[2] != 0x00)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_VALUE);
//coils are stored msb->lsb so we must use 7-address
if(modbus_rx.data[2] == 0xFF)
bit_set(coils,7-modbus_rx.data[1]);
bit_clear(coils,7-modbus_rx.data[1]);
modbus_write_single_coil_rsp(MODBUS_ADDRESS,modbus_rx.data[1],((int16)(modbus_rx.data[2]))<<8);
event_count++;
case FUNC_WRITE_SINGLE_REGISTER:
if(modbus_rx.data[0] || modbus_rx.data[1] >= 8)
//the registers are stored in little endian format
hold_regs[modbus_rx.data[1]] = make16(modbus_rx.data[3],modbus_rx.data[2]);
modbus_write_single_register_rsp(MODBUS_ADDRESS,
make16(modbus_rx.data[0],modbus_rx.data[1]),
make16(modbus_rx.data[2],modbus_rx.data[3]));
case FUNC_WRITE_MULTIPLE_COILS:
int i,j;
modbus_rx.data[5] = swap_bits(modbus_rx.data[5]);
for(i=modbus_rx.data[1],j=0; i < modbus_rx.data[1]+modbus_rx.data[3]; ++i,++j)
if(bit_test(modbus_rx.data[5],j))
bit_set(coils,7-i);
bit_clear(coils,7-i);
modbus_write_multiple_coils_rsp(MODBUS_ADDRESS,
event_count++;
case FUNC_WRITE_MULTIPLE_REGISTERS:
int i,j;
for(i=0,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
hold_regs[i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
modbus_write_multiple_registers_rsp(MODBUS_ADDRESS,
event_count++;
default: //We don't support the function, so return exception
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_FUNCTION);
In this part of library doesn't expect error mode:
#if( MODBUS_SERIAL_INT_SOURCE == MODBUS_INT_RDA )
#use rs232(baud=MODBUS_SERIAL_BAUD, UART1, parity=N, stream=MODBUS_SERIAL)
Here occurs error:
#if (MODBUS_SERIAL_INT_SOURCE != MODBUS_INT_EXT)
#bit TRMT=TXSTA.1
#define WAIT_FOR_HW_BUFFER()\
while(!TRMT);\
Posted: Thu Sep 15, 2011 3:19 pm |
| Quote: | But even i am not successful to compile original codes.
Post your compiler version so we can install it and try to duplicate your
problem. It could be a problem with your version only. Post it. |
koray_duran
Posted: Mon Sep 19, 2011 6:57 am |
IDE 4.057
PCB 4.068
PCM 4.068
PCH 4.068
PCD 4.057 |
Posted: Mon Sep 19, 2011 1:30 pm |
In vs. 4.068, I had to fix the following problems in modbus.c.
There are two #use rs232() statements near the start of the file that
have "error" as a parameter. It should be "errors", as shown in bold below:
| Quote: |
#use rs232(baud=MODBUS_SERIAL_BAUD, UART1, parity=N, stream=MODBUS_SERIAL, errors) // *** FIXED
#define RCV_OFF() {disable_interrupts(INT_RDA);}
#elif( MODBUS_SERIAL_INT_SOURCE == MODBUS_INT_RDA2 )
#use rs232(baud=MODBUS_SERIAL_BAUD, UART2, parity=N, stream=MODBUS_SERIAL, errors) // *** FIXED
#define RCV_OFF() {disable_interrupts(INT_RDA2);}
The fact that it has that simple error implies that the released version of
modbus.c was never tested fully in vs. 4.068. I tested Vs. 4.124 doesn't
have this problem.
The next problem is caused by your choice of a PIC. The 18F67J60 has
two hardware UARTs, so there is no TXSTA. There is instead, TXSTA1
and TXSTA2. So to fix the problem, edit the lines to say "TXSTA1".
| Quote: |
#byte TXSTA1=getenv("sfr:TXSTA1")
#bit TRMT=TXSTA1.1
koray_duran
Posted: Tue Sep 20, 2011 9:10 am |
Thanks PCM Programmer
I should mind it before! |
