magic_mauve
| #FUSE HSPLL problem |
Posted: Wed Sep 14, 2011 3:40 am |
I am using compiler version 4.100 and PIC18F4680 and can't set the fuse for HSPLL within the code. I get the following error:
Line 58(7,13): Unknown keyword in #FUSES "HSPLL"
However, I can set it ok when I manually set the configuration bits every time I compile, which is a pain.
I assume it is a compiler bug, but am reluctant to upgrade my compiler. Does anyone know a work-around?
I tried using #FUSES 1=0x0C00 and this compiles but the PLL is off.
Many thanks
magic_mauve |
Posted: Wed Sep 14, 2011 9:40 am |
On this compiler version, for this chip, the fuse is 'H4', not HSPLL.
The fuses in this area are at times really designed to confuse, with CCS not being reliable in their naming - always start by reading the first few lines on the include file for the chip, where legal fuses are listed, and then see if you can work out the one you want!....
magic_mauve
Posted: Wed Sep 14, 2011 10:05 am |
Thanks for your speedy response. I have tried H4, which compiles ok, but has no effect on the speed of my program. When I set HS+PLL in the config bits everything speeds up.
Is there something else I should be doing?
magic_mauve |
Posted: Wed Sep 14, 2011 2:42 pm |
The simple way to find out what is actually programmed is to look at the last few lines of the hex file. It may well be that your compiler version does not correctly set the PLL on this chip.
Posted: Wed Sep 14, 2011 3:08 pm |
the Micro engineering Labs USB PIC programmer has a
very nice fuse option window that lets you see and manipulate
the fuses in your HEX file
i've used it several times to verify , then alter, and resave --
only the fuses in an already compiled file, with "great joy". |
Posted: Wed Sep 14, 2011 3:28 pm |
Try this test program. Install a 10 MHz crystal (and capacitors) on the
PIC and see if the LED blinks once per second (1 Hz).
#include <18F4680.h>
#fuses H4,NOWDT,PUT,BROWNOUT,NOPBADEN,NOLVP
#use delay(clock=40M)
output_toggle(PIN_B0); // Blink LED
magic_mauve
Posted: Thu Sep 15, 2011 2:32 am |
Thanks for all this advice. I have made progress as I can spot the byte I need to change in the hex file to set up the PLL correctly. Does anyone know how the checksum is calculated for a line in the hex file? This needs changing too before I can program.
magic_mauve |
Posted: Thu Sep 15, 2011 4:10 am |
The checksum is 'standard' Intel Hex. Any number of websites giving details of this.
However you can just set the byte using a #ROM statement, and the checksum is then calculated for you.
Do you have the IDE?. If so, you can set the fuses from the device editor.
However getting more puzzled what is going on.....
Just took PCM programmer's demo program. Compiled it 'as is', with 4.100, loaded it into my programmer, and it correctly has the PLL setup.
The compiler _is_ setting the bits correctly.
Loading it into MPLAB, gives:
300001 06 OSC Oscillator HS-PLL enabled freq=4xFosc1
Then, just to be sure, went back in time to V4.070, and this too sets the PLL correctly. Then tried 4.104, and so does this.
//From 4.070
Configuration Fuses:
Word 1: 0600 H4 NOIESO NOFCMEN RESERVED
Word 2: 1E1E BROWNOUT NOWDT BORV21 PUT WDT32768
Word 3: 8000 NOPBADEN NOLPT1OSC MCLR RESERVED
Word 4: 0081 STVREN NODEBUG NOLVP BBSIZ1K NOXINST RESERVED
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
//From 4.100
//From 4.104
Word 1: C600 H4 IESO FCMEN
Word 3: 8400 NOPBADEN LPT1OSC MCLR
Word 4: 00B1 STVREN NODEBUG NOLVP NOXINST BBSIZ4K
All are correctly setting the PLL.
Then tried another test. Manually set the byte using the #fuses statement to '0' (just as a test), and it happily sets the register to 0:
Word 1: 0000 LP NOIESO NOFCMEN
Word 3: 8600 PBADEN LPT1OSC MCLR
You have something else getting in the way. Are you _sure_ your programmer is setup to read the fuses from the incoming file?.
Are you sure you don't have a #ROM somewhere in the code, or another #fuses line being loaded?.
The problem is _not_ with the compiler.
magic_mauve
Posted: Thu Sep 15, 2011 8:15 am |
Thank you. I got the same results as you and I have now found the problem.
I was using
#use DELAY(crystal=16000000)
when I changed this to:
#use DELAY(clock=16M)
H4 gets set correctly.
Many thanks for your help. |
