Posted: Mon Sep 12, 2011 4:11 pm |
In his main() code, he has this:
| Quote: |
NOKIA_INIT();
NOKIA_GOTOXY(1,1);
printf(nokia_printchar,"M.Yasser");
NOKIA_GOTOXY(20,10);
PRINTF(NOKIA_PRINTCHAR,"A Test!!");
printF(nokia_printchar,"NOKIA 3310 LCD");
He's displaying constant strings. So I guess your question is how to use
printf to displays a string array, or how to display numbers.
Download the CCS manual and put it on your desktop.
Look in the section on printf. It shows the template of how to do it:
| Quote: |
printf (fname, cstring, values...)
fname = nokia_printchar
cstring = the format string used to display the desired type of variable.
values = the variables that you want to display.
Here is an example of how to display an 8-bit unsigned variable in
decimal format:
int8 temp;
nokia_init();
nokia_gotoxy(1,1);
temp = 25;
printf(nokia_printchar, "%u", temp);
To display other variables of a size larger than 8-bit, or a different type
than an integer, etc., then read the CCS manual and look at the format
strings in the printf section, such as %lu, %x, %lx, %f, %7.3f, etc. |
