16F87 and BootLoader
Kilobravo
PostPosted: Fri Sep 09, 2011 5:26 am     Reply with quote
New to the forum, I have a 16F87 and Max3222 at 3.3V I am trying to bootload a program and everytime I do it seems like the chip becomes unresponsive. I am using the tiny bootloader. I have had good succcess with it on the 16F88 chips at 5V.
I tried to compile the Microchip Bootloader, it seems to compile fine but the PC software does not find the boot loader on the chip.
I had RB3 tied to gnd and I am not using the RB6 or RB7. I am using the internal osc at 8 mhz.
Any suggestions on what to try ? I can program the bootloader and it seems fine as soon as I program the "program" it will run fine until I reset the chip and then the chip is unresponsive. I am using CSC C v4.14. I think the C code is trashing the bootloader on reset, the bootloader and my coed works fine until I hit reset on MCLR ? Anybody know how to fix this ?
Thanks !
PostPosted: Fri Sep 09, 2011 8:08 am     Reply with quote
Since you had it 'working' with the 5volt 88, then perhaps it's the RS232 interface that's causing you problems.
1) can you run the working code on an 87 with a 5V power supply ?
2) are there ANY changes in the PC platform ?
3) can a simple 'loopback using the MAX3222 work on the PC terminal prgram ?
report back and we'll scratch our heads some more !!
Kilobravo
PostPosted: Fri Sep 09, 2011 5:54 pm     Reply with quote
I'll try and duplicate the setup on the F88 at 5volts.
It seems strange the downloaded code works fine until reset.
I think it might be a problem with the CCS code generating.
I can't get a simple flashled, hello world program to work.
It will run forever when downloaded as soon as I hit reset the chip is unresponsive and the bootloader is gone ???
Kilobravo
PostPosted: Mon Sep 19, 2011 2:53 pm     Reply with quote
Just to close this out, I left the unused pins on the Max3222 floating. This was a bad idea. Once I grounded the unused pins I had reliable comms.
It was fine with the MAX232, but not the MAX3222.
