flex_lcd driver and 18F4620
doggitz
PostPosted: Tue Sep 06, 2011 10:16 pm     Reply with quote
I am having a devil of a time with a simple task. Using a known good combination of a 2X16 LCD (JHD 162A) and an 18F4620. I just cannot make this work with a PCWH compiler. Has anyone used this combo? Pin assignments are:
#define LCD_DB4   PIN_D0
#define LCD_DB5   PIN_D1
#define LCD_DB6   PIN_D2
#define LCD_DB7   PIN_D3
#define LCD_E     PIN_D5
#define LCD_RS    PIN_D4
//#define LCD_RW    PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW   1
Using PICKIT 2 programmer - works fine with flash LED program
Help, please !
PostPosted: Wed Sep 07, 2011 5:13 am     Reply with quote
Obvious first comment. You have got the R/W pin on the LCD pulled low?.
However most likely thing is what else PortD is used for. Have you got the line:
setup_psp(PSP_DISABLED);
in your initialisation?.
