math function: pow(X,Y) error
Piccolo
PostPosted: Tue Aug 30, 2011 12:37 pm     Reply with quote
Hello Forum,
I am using a PIC16F866 with CCS compiler version 4.124.
It seems the math.h function pow(X,Y) does not behave, or I'm missing something (quite possible).
Here's my code snippet:
void CalcDewPoint(void)
    float32 e, es;//vapor pressure when given temperature (in millibars).
    float32 logs;
    // e is vapor pressure when given dewpoint (in millibars).
    // DryBulbTemp is in °C.
    // RelHum is %Relative Humidity.
//!    e = DryBulbTemp * 7.5;
//!    es = DryBulbTemp + 237.7;
    e = 163.3;
    es = 259.5;
    e = e/es;
    es = pow(10.0,e);
    es *= 6.112;
    e = (es*RelHum);
    e /= 100.0;
    es = -430.22;
    logs = 237.7*log(e);
    es += logs;
    logs = log(e);
    logs *= -1.0;
    logs += 19.08;
    DewPtTemp = es/logs;
Piccolo
PostPosted: Tue Aug 30, 2011 12:43 pm     Reply with quote
Sorry, I must have hit a wrong button, as I was not finished with my query.
I tried this code with a PIC24 part, and when I used float64 the code ran properly.
I cannot use float64 with PIC16 part.
does anyone know if the pow(X,Y) function for float32 is buggy? I did scan the forum, but found only some older posts regarding this.
I did run this code with version 3 compiler, but then I had a different PIC, and I don't have a device file for PIC16F886 for version 3.
Any suggestions greatly appreciated.
Best regards,
piccolo
foxabilo
PostPosted: Tue Aug 30, 2011 1:08 pm     Reply with quote
Not sure if the pow function has any bugs but one thing I always do regardless of the value is typecast any numbers in my code, one thing I notice is the use of 1.0, I'm not sure if the compiler will see this as actualy 1 and thus make it an INT.
Try preceeding all fixed values with the typecast e.g
e=e+(float32)1.0
that should in theory not be needed for values with decimals but something I always do to avoid problems.
What is the actual numerical error you get, can you post a simplified bit of code with example output that shows the error?
Fox
Piccolo
PostPosted: Tue Aug 30, 2011 2:30 pm     Reply with quote
Here's some more information:
with this code,
#include "math.h"
float Value;
void CalcPOW(void)
Value = pow(10,0); //should be 1 but actual result is 127.00000
Value = pow(10,1); //should be 10 but actual result is -0.03711
Value = pow(10,2); //should be 100 but actual result is 0.00000
Value = pow(10,3); //should be 1000 but actual result is 0.00000
Value - pow(2,0); //should be 1 but actual result is 127.00000
I output the Value to serial port using
printf("%3.5f", Value);
It does not matter if I use 10 or 10.0, and it makes no difference if I typecast the values.
Also, I am using this in the header file above the FUSES:
#device *=16
piccolo
Piccolo
PostPosted: Tue Aug 30, 2011 2:34 pm     Reply with quote
Here's the ASM output:
....................      Value = pow(10,0);
0F84:  CLRF   58
0F85:  CLRF   57
0F86:  MOVLW  20
0F87:  MOVWF  56
0F88:  MOVLW  82
0F89:  MOVWF  55
0F8A:  CLRF   5C
0F8B:  CLRF   5B
0F8C:  CLRF   5A
0F8D:  CLRF   59
0F8E:  GOTO   5DF
0F8F:  MOVF   7A,W
0F90:  MOVWF  54
0F91:  MOVF   79,W
0F92:  MOVWF  53
0F93:  MOVF   78,W
0F94:  MOVWF  52
0F95:  MOVF   77,W
0F96:  MOVWF  51
....................      DewPtTemp = Value;
0F97:  MOVF   54,W
0F98:  MOVWF  33
0F99:  MOVF   53,W
0F9A:  MOVWF  32
0F9B:  MOVF   52,W
0F9C:  MOVWF  31
0F9D:  MOVF   51,W
0F9E:  MOVWF  30
PostPosted: Tue Aug 30, 2011 2:35 pm     Reply with quote
This PIC doesn't exist.
Piccolo
PostPosted: Tue Aug 30, 2011 2:37 pm     Reply with quote
Sorry, I am using the PIC16F886
PostPosted: Tue Aug 30, 2011 2:54 pm     Reply with quote
Are you _sure_ you are loading the math.h, that corresponds to the compiler?. I have seen this, when a V4 compiler was used to compile code that had previously been compiled with a V3 compiler, and was still loading the math.h library from the V3 compiler. V4 changes the way that pointer arithmetic is done to the correct C behaviour, but parts of the old V3 library use pointer arithmetic assuming the 'old' behaviour, and give screwy results if compiled with V4.
You mention having previously used a V3 compiler, so check this.
PostPosted: Tue Aug 30, 2011 3:06 pm     Reply with quote
I took your last program and made it into a test program and ran it in
MPLAB Simulator (MPLAB vs. 8.73a) and I got the following output:
1.00000
10.00000
99.99999
999.99992
1.00000
1.000
10.000
99.999
999.999
1.000
1.000
10.000
100.000
1000.000
1.000
Top of .LST file:
CCS PCM C Compiler, Version 4.124, xxxxx 30-Aug-11 14:02
Filename: C:\Program Files\PICC\Projects\PCM_Test\pcm_test.lst
ROM used: 3996 words (49%)
Largest free fragment is 2048
RAM used: 10 (3%) at main() level
74 (20%) worst case
Stack: 5 locations
Build results:
Memory usage: ROM=49% RAM=3% - 20%
0 Errors, 2 Warnings.
Loaded C:\Program Files\PICC\Projects\PCM_Test\pcm_test.cof.
BUILD SUCCEEDED: Tue Aug 30 14:02:06 2011
Test program:
#include <16F886.H>
#use delay(clock=4M)
#include "math.h"
float Value;
void CalcPOW(void)
printf("%3.5f \r", Value);
Value = pow(2,0); //should be 1 but actual result is 127.00000
printf("\r");
// Change width and precision fields so 1st one is higher than the last one:
printf("%5.3f \r", Value);
printf("\r");
printf("%5.3g \r", Value);
printf("\r");
CalcPOW();
Piccolo
PostPosted: Tue Aug 30, 2011 3:09 pm     Reply with quote
That was the problem! My project Options->Include Files was pointing to the version 3 compiler Drivers folder. the code is working as expected now, but I've got to do some trimming somewhere as the version 4 compiler gives me an out of ROM error, but at least the POW(X,Y) function issue appears resolved. Thank you for your assistance and great suggestions.
Best regards,
piccolo
