		| Author | Message |
		| uN_Eof
 Location: I live in Spain, with the toros, paella and tortilla
				| Slave SPI Inhibits SCK |
				|  Posted: Tue Aug 30, 2011 5:12 am |   |
				| Hello all. I'm having a problem, when I configure SPI as a slave in a PIC18F4620 the PIC inhibits the clock signal coming from the master. SCK is always 0, and I don't know why. Here is a piece of my code, if it helps.
  	  | Code: |  	  | void dsconf(){
 input(DSATT);
 input(DSCMD);
 input(DSCLK);
 setup_spi(SPI_SLAVE);
 setup_spi(SPI_H_TO_L);
 setup_spi(SPI_XMIT_L_TO_H);
 enable_interrupts(INT_SSP);
 ack(unsigned int us){
 output_low(DSACK);
 delay_us(us);
 input(DSACK);
 void write(unsigned int data, int doack=1){
 spi_write(data);
 if(doack)
 ack(12);
 #INT_SSP
 void ssp_isr(){
 command = spi_read();      //IMPORTANT STUFF
 if(command == 0x01){
 bytecount = 0;
 output_high(green_led);
 bytecount++;            //INCREMENT BYTE COUNT
 switch (bytecount){
 case 1:
 if(digital)
 //write(0x41);
 write(0xFE,1);
 if(analog)
 write(0x79,1);
 if(config)
 write(0xFF,1);
 case 2:
 if(command == 0x42){
 config = 0;
 write(0x5A,1);
 if(command == 0xFF){
 config = 1;
 write(0x5A,1);
 write(0x5A,1);
 case 3:
 if(config == 0 && command == 0x00){
 write(0xBD,1);
 case 4:
 write(0xFF,0);
 if(digital && !config)
 bytecount = 0;
 case 5:
 if(command == 0x00 && analog && !config){
 write(rxjoy);
 case 6:
 write(ryjoy);
 case 7:
 write(lxjoy);
 case 8:
 write(lyjoy);
 case 9:
 if(rtstat){
 write(0xFF);
 } else {
 write(0x00);
 case 10:
 if(ltstat){
 write(0xFF);
 } else {
 write(0x00);
 case 11:
 if(upstat){
 write(0xFF);
 } else {
 write(0x00);
 case 12:
 if(dwnstat){
 write(0xFF);
 } else {
 write(0x00);
 case 13:
 if(tristat){
 write(0xFF);
 } else {
 write(0x00);
 case 14:
 if(circstat){
 write(0xFF);
 } else {
 write(0x00);
 case 15:
 if(sqrstat){
 write(0xFF);
 } else {
 write(0x00);
 case 16:
 if(xstat){
 write(0xFF);
 } else {
 write(0x00);
 case 17:
 if(l1stat){
 write(0xFF);
 } else {
 write(0x00);
 case 18:
 if(r1stat){
 write(0xFF);
 } else {
 write(0x00);
 case 19:
 if(l2stat){
 write(0xFF);
 } else {
 write(0x00);
 case 20:
 if(r2stat){
 write(0xFF);
 } else {
 write(0x00);
 Thanks in advance.
 Some additional info: I'm trying to emulate a PS2 controller, and I'm connecting my emulator (slave) to a PS2 to PS3 usb controller adaptor, but the same thing happens if I connect the slave to an actual PS2.
		| RF_Developer
				|  Posted: Tue Aug 30, 2011 6:11 am |   |
				| I'm pretty sure setup_spi() doesn't work incrementally.  In your code only the values in the last setup_spi will have any effect. Instead you have to or the values together in one setup_spi:
 setup_spi(SPI_SLAVE | SPI_H_TO_L | SPI_XMIT_L_TO_H);
 That might help.
 RF Developer
		| uN_Eof
				|  Posted: Tue Aug 30, 2011 6:14 am |   |
				|  	  | RF_Developer wrote: |  	  | I'm pretty sure setup_spi() doesn't work incrementally.  In your code only the values in the last setup_spi will have any effect. Instead you have to or the values together in one setup_spi:
 That might help.
 RF Developer
 THANKS! Thank you so much... that seems to solve my problem... nobody knows how much I hate this kind of idiotic errors.... haha
 | You cannot post new topics in this forum You cannot reply to topics in this forum
