MPLAB Won't Watch Some Variables
nurquhar
PostPosted: Thu Aug 25, 2011 7:48 am     Reply with quote
USING :
MPLAB 8.76
CCS PCM C Compiler, Version 4.123
PIC12F1840
I am trying to debug some code and noticed that some of my variables, structures and are not correctly shown in the WATCH window.
For example I have
#define   MAXCMDPARA   4
// Group Command Structure
typedef struct {
   uint8   len ;      // Command Group length
   char   cmd ;      // Command Type
//   uint16   adr ;      // Command Address
   uint8   adr ;      // Command Address
   uint8   para8[MAXCMDPARA] ;   // Parameters
} CmdGroup ;
// Group Command
CmdGroup grp ;
Which show in the .SYM files as :
04A-050 grp
But when I put 'grp' into the watch window it gives it the incorrect address of 000 rather than the expected 04A. It does however correctly give a '+' button which can show all the correct member symbols.
Is this an MPLAB or CCS issue Question
PostPosted: Sat Aug 27, 2011 1:51 pm     Reply with quote
For us to work on this, you need to post a complete (but extremely short)
test program that we can copy-and-paste into MPLAB, and compile and test.
PostPosted: Tue Aug 30, 2011 2:25 am     Reply with quote
As a comment on this, you do realise that _local_ variables (ones declared inside a function), are not 'active', unless/until the debugger is inside the function that declares them. The same memory is re-used for other things when you are in other functions, and they will behave as you are describing.
