Prime8 Serial numbering doesn't work
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
edwardMaco
PostPosted: Mon Aug 22, 2011 8:45 pm     Reply with quote
Has anyone managed to get the Prime8 to successfully program unique serial numbers to multiple devices?
Whenever I try to program anything with a serial number it says the download failed and the log shows this:
FailureAccess violation at address 0076E0E5 in module 'ccsload.exe'. Read of address 00000000
It doesn't program with the command-line interface either.
Serial numbers seem to work when I try programming using Linux but the Prime8 is identified as an ICD-S and will only program slot 1.
Has anyone else had this problem? It only occurs when I use the automatic serial numbering. The hex files all seem to program correctly otherwise.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
