				 Posted: Mon Aug 22, 2011 2:49 pm     |
				That's LCD character set A02. Are you sure that your LCD has that
character set ?
First you need to find out if you really have the A02 character set.
Run the following program which will display all chars in the range from
0xA0 to 0xBF (on rows 1 and 2 of the LCD).
#include <16F877.H>
#include "flex_lcd.c"
#define LCD_COLUMN_ADDRESS  0xA0
int8 i;
// Display two columns in the LCD character set,
// starting at the address of the first column,
// as specified in LCD_COLUMN_ADDRESS.
for(i = 0; i < 32; i++)
    if(i == 16)
       lcd_putc('\n');
    lcd_putc(i + LCD_COLUMN_ADDRESS);
If you have character set A02, you will see the double-bar character in
the upper left corner of the LCD.    But I think most LCD's have the A00
character set, or some variation of it.  In which case, there is no character
at address 0xA0 in the table.
But anyway, if you do have a character there in your LCD's character set
then you can display it with:
lcd_putc(0xA0);  // Display double-bar character
