16F1937 and PWM [solved]
curt2go
PostPosted: Fri Aug 19, 2011 9:58 am     Reply with quote
I am having issues with the PWM on this part. I have used PWM on many other parts. I don't really care about the frequency right now just trying to get something working.
Compiler 4.124
I am setting the timer 2 setting up the CCP4 and setting the duty just like always. Is there something I am missing here?
setup_ccp4(CCP_PWM | CCP_TIMER2);
setup_timer_2(T2_DIV_BY_1, 0x33,1);
setup_oscillator(OSC_8MHZ);
set_pwm4_duty(512);
curt2go
PostPosted: Fri Aug 19, 2011 10:57 am     Reply with quote
Update... I am able to get PWM1 running.. so the trouble is with PWM4. Let me know if anyone has some thoughts.
curt2go
PostPosted: Fri Aug 19, 2011 12:03 pm     Reply with quote
Problem solved! The CCS compliler is not setting thr TRISD bit properly in the setup_ccp4. So I have to do it manually.
Hopefully this will get fixed in an update.
