Int32 and float problems
Markus
PostPosted: Thu Oct 24, 2002 9:28 pm     Reply with quote
I am programming an 877 and encountering a few problems with int32 and floats. The program is large (takes up \%55 of PIC ROM and \%80 of PIC RAM) and currently uses long's as its largest variable. I am required to change the long's to int32's but when I do the program functions erratically. Normally the program starts with an intro displayed on an LCD display. When I change to int32 it displays garbage and doesn't perform any of the operations required. I have managed to change one long into an int32 and it worked fine, but any more than one the problems occured. Please help.
Markus
___________________________
Original Post ID: 8169
Sherpa Doug
Re: Int32 and float problems
PostPosted: Fri Oct 25, 2002 7:16 am     Reply with quote
:=Hi,
:=I am programming an 877 and encountering a few problems with int32 and floats. The program is large (takes up \%55 of PIC ROM and \%80 of PIC RAM) and currently uses long's as its largest variable. I am required to change the long's to int32's but when I do the program functions erratically. Normally the program starts with an intro displayed on an LCD display. When I change to int32 it displays garbage and doesn't perform any of the operations required. I have managed to change one long into an int32 and it worked fine, but any more than one the problems occured. Please help.
:=Markus
There is not much we can do unless you post some code....
Are you using #seperate? If so maybe you have stack overflow?
How much does the RAM/ROM grow when you switch to INT32. How are floats involved?
Original Post ID: 8192
Markus
PostPosted: Fri Oct 25, 2002 11:59 pm     Reply with quote
:=:=Hi,
:=:=I am programming an 877 and encountering a few problems with int32 and floats. The program is large (takes up \%55 of PIC ROM and \%80 of PIC RAM) and currently uses long's as its largest variable. I am required to change the long's to int32's but when I do the program functions erratically. Normally the program starts with an intro displayed on an LCD display. When I change to int32 it displays garbage and doesn't perform any of the operations required. I have managed to change one long into an int32 and it worked fine, but any more than one the problems occured. Please help.
:=:=Markus
:=There is not much we can do unless you post some code....
:=Are you using #seperate? If so maybe you have stack overflow?
:=How much does the RAM/ROM grow when you switch to INT32. How are floats involved?
Thanks to both of you for replying so quick, I also apologise for the numerous posting of the same question, I was getting an error when I tried to post the question, so I assumed they weren't working, I was wrong. I tried to delete the excess but I just got more error's.
I will try to get some of the code to you next week, but to answer your other questions, I'm not using #seperate; when I use one INT32 I get a 5\% increase in RAM and a minimal change in ROM; I'm not using any floats at the moment, I just tried them when the problem occurred with INT32 and found the same problem occurring.
Markus
Original Post ID: 8203
