printf can handle only two hex digits?
Chen
PostPosted: Fri Feb 07, 2003 9:28 am     Reply with quote
unsigned int16 i=0x5678;
char string [20];
byte stringptr=0;
tostring(char c){
if (c=='\f')
stringptr=0;
string[stringptr++]=c;
string[stringptr]=0;
printf(tostring, "\f\%4X", i);
----> string = "0078" instead of "5678"!
___________________________
Original Post ID: 11388
Hans Wedemeyer
Re: printf can handle only two hex digits?
PostPosted: Fri Feb 07, 2003 9:48 am     Reply with quote
You need to tell printf()it is a long..
like this
:=unsigned int16 i=0x5678;
:=printf(tostring, "\f\%4LX", i);
Original Post ID: 11390
Chen
wow,
PostPosted: Fri Feb 07, 2003 10:16 am     Reply with quote
a 16-bit integer is already a long!
:=You need to tell printf()it is a long..
:=like this
:=:=unsigned int16 i=0x5678;
:=:=printf(tostring, "\f\%4LX", i);
Original Post ID: 11393
R.J.Hamlett
Re: wow,
PostPosted: Fri Feb 07, 2003 10:50 am     Reply with quote
:=a 16-bit integer is already a long!
:=Thanks
Yes, but _printf_ is designed to accept the default short integer by standard. If you are passing it a long, it requires the 'L' format (this works for both 16bit and 32bit 'longs).
:=:=You need to tell printf()it is a long..
:=:=like this
:=:=:=unsigned int16 i=0x5678;
:=:=:=printf(tostring, "\f\%4LX", i);
Original Post ID: 11394
Sherpa Doug
Re: wow,
PostPosted: Fri Feb 07, 2003 11:27 am     Reply with quote
:=Thanks
Check out the definition of a short.
Original Post ID: 11397
