raflab
| Problem with interruptions PIC 16F628a + PCM compiler v4.068 |
Posted: Tue Aug 09, 2011 2:27 am |
My project is to receive data with serial communication from VB.net. This data will be used as a delay to switch on and to switch off 3 leds !! So the algorithm is as follows:
In the PC we have 3 buttons !! When the user launch the PC-Interface he will push the"CONNECT" button (the vb will send "1" to the pic), the pic will send the currents values of the delays (a1,b1,a2,b2) after receiving this delays !!
The user have the choice between two button !! the first !! pushing the "CONFIGURATION MODE" in VB interface !! (VB will send "2" to the pic will send "F" or "C" according to the state of the switch connected to RB0 when the pic send "C" so it's ok !! We can send new delays ... after typing the new data the user press "SEND" a message will appear to confirm his choice (VB.net will send the new delay and pic will response will the same data ) so after user's confirmation the pic will save the new delays in his EEPROM.
Also it exist another button "FUNCTIONAL MODE" but this function is not important. So my problem is when I send Minutes the pic will not be able to manage the interruptions !! So I think that the problem is in the 'minute' function and I have doubts about the int_ext interruption.
Please if someone can help me I will be very grateful ) this is my code :
#include <16F628A.h>
#FUSES LP //Low power osc < 200 khz
#FUSES NOMCLR //Master Clear pin used for I/O
#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8)
#include <stdlib.h>
#include <string.h>
#use delay (clock=4000000)
#use rs232 (baud=9600, xmit=pin_b2, rcv=pin_b1, parity=N, stop=1)
#define so 10 // définir les adresse mémoir EEPROM qu'on va les utiliser
#define mo 15
#define sf 20
#define mf 25
unsigned char send[5],c[5],etat[5],select[5],chaine1[20],chaine2[20],str1[20],str2[20]; // déclaration d'une chaine de caractères d'une taille maximale 20
unsigned int16 s=0,x1=0,y1=0,x2=0,y2=0,a1=0,b1=0,a2=0,b2=0; // déclaration d'un entier non signé de longueur 16 bits
unsigned int1 k=0;
unsigned int z=0,w,x=0,j,i=0;
#int_ext
void ext_isr()
//DISABLE_INTERRUPTS(INT_ext);
if(!input(pin_b0)){
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);
output_high(pin_a2);
output_low(pin_a1);}
#int_timer0
void timer(){
z=0;
if(kbhit()){
gets(select);
x=atoi(select);
switch(x){
case 1:{
printf("%lu\r",a1); // time of LED lighting in seconds
printf("%lu\r",b1); // time of LED lighting in minutes
printf("%lu\r",a2); // time of LED switched off in seconds
printf("%lu\r",b2); // time of LED switched off in minutes
case 2:{
j=2;
strcpy(c,"2");
if(input(pin_b0))
printf("%s\r","F");
while(input(pin_b0)&& j==2) // boucle pour passer au mode config si on l'est pas deja
//delay_ms(1000);
gets(c);
j=atoi(c);
output_high(pin_a1);
output_low(pin_a2);
if(input(pin_b0)&& j!=8)
printf("%s\r","F");
if(j!=8){
printf("%s\r","C");
output_low(pin_a1);
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);}
while(z==0 && j!=8 ){
gets(send);
printf("%s\r",send);
s=atol(send);
if(s==4){
gets(chaine1); // acquisition des nouveaux valeurs
gets(str1);
gets(chaine2);
gets(str2);
x1=atol(chaine1); // conversion chaine -> entier long
y1=atol(str1);
x2=atol(chaine2);
y2=atol(str2);
printf("%s\r",chaine1); // renvoyer les valeurs reçu pour une confirmation de l'utilisateur
printf("%s\r",str1);
printf("%s\r",chaine2);
printf("%s\r",str2);
gets(select);
w=atoi(select);
if (w==1) {
a1=x1;
a2=x2;
b1=y1;
b2=y2;
write_eeprom(so,a1);
write_eeprom(mo,b1);
write_eeprom(sf,a2);
write_eeprom(mf,b2);
a1=a1*1000;
a2=a2*1000;
z=1;
z=0;
z=1;
case 3:{
j=3;
strcpy(c,"3");
if(input(pin_b0)==0)
printf("%s\r","C");
while(input(pin_b0)==0 && j==3) // boucle pour passer au mode config si on l'est pas deja
gets(c);
j=atoi(c);
if((input(pin_b0)==0) && j!=9 )
printf("%s\r","C");
if (j!= 9)
printf("%s\r","F");
void minute (int16 m){ // procédure qui fait un durée d'attente de m minutes
while(m>0){
delay_ms(60000);
m--;}
EXT_INT_EDGE(H_TO_L);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
set_timer0(60);
// TODO: USER CODE!!
enable_interrupts(GLOBAL);// autorisé tout les intérruptions
a1=read_eeprom(so);
b1=read_eeprom(mo);
a2=read_eeprom(sf);
b2=read_eeprom(mf);
a1=a1*1000;
a2=a2*1000;
enable_interrupts(INT_EXT);
enable_interrupts(int_timer0);
if((input(pin_b0))){
output_high(pin_b4);
output_high(pin_b5);
output_high(pin_b6);
output_high(pin_b7);
output_low(pin_a2);
delay_ms(a1);
minute(b1);
output_low(pin_a2);
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);
delay_ms(a2);
minute(b2);
output_low(pin_a1);
Posted: Tue Aug 09, 2011 4:18 am |
Your chip has a hardware UART. Use this for your serial. Otherwise you have not got a hope.
Keep interrupt handlers _SHORT_. You _must_ get out again quickly, or something will suffer. You have perhaps 1000* as much code in the timer interrupt as is acceptable, with things that themselves use a lot of arithmetic, and take a long time.
On wake up, INTEDG, defaults to '1', which means that INT_EXT triggers when pin B0, goes from low to high. You then test B0 in the interrupt routine, and change various pins, if it is low. This will only happen, if B0, has gone high for less than perhaps 30uSec.
Don't keep re-enabling the interrupts in the loop.
raflab
Posted: Tue Aug 09, 2011 4:45 am |
Thx for the fast response ) So I will replace the timer0 with int_rda interruption ?? and the treatment of the interruption must be as quickly as it possible !! But even if I do that the problem of the "Minute" function still appear. When I do data acquisition from the VB.net interface and I use that data in 'minute' the PIC can't manage the interruption like he's doing when the delay is only in second :( |
