external interrupt 12F683
sl001
PostPosted: Thu Aug 04, 2011 10:08 pm     Reply with quote
Hi Guys,
PCWH Version:4.106
I am attempting to use a simple external ISR that is entered each time GP2 goes from (H_TO_L). I have a pullup to this pin with a button to ground. I'm using the ccs 12f683 dev board.
However, the LED stays on forever, i.e. the isr is not being serviced?
#include <12f683.H>
#device ICD=TRUE
#fuses intrc_io,nomclr,nowdt,noprotect
#INT_EXT
void ext_isr() // This is the routine that is run each time an external interrupt is triggered.
   delay_ms (20);  //debounce
   output_high (RED_LED);        //contactor off (Engine Ign off)
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
   do
   output_low (RED_LED);   //Contactor 'on' Engine Running
   while (TRUE);
PostPosted: Fri Aug 05, 2011 5:52 am     Reply with quote
Unless you have something like a fast scope, would you ever know the interrupt was being serviced?.
If the code goes into the ISR, the LED line will go high, and then less than 20 instructions later will go low again. 20uSec. You'll never see this.
Move your time delay in the interrupt to after changing the LED, and you then will have a chance.
sl001
PostPosted: Sat Aug 06, 2011 2:23 am     Reply with quote
Thankyou, you are quite right. However, the ISR is still not being serviced? i.e. RED_LED is remaining lit.
I wonder if there is an issue with this version of compiler?
#INT_EXT
void ext_isr()
   delay_ms(2000);
PostPosted: Sat Aug 06, 2011 3:18 am     Reply with quote
Took the code.
Selected same compiler version.
Added a definition for RED_LED.
Compiled.
Pulsed GP2 line low.
Interrupt fired.
#include <12F683.h>
#device adc=8
#FUSES INTRC_IO                    //Internal RC Osc
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#define RED_LED PIN_A1
#INT_EXT
void ext_isr() {
   delay_ms (200);  //long enough to be visible
void main() {
   clear_interrupt(INT_EXT); //May be fired by setting the edge
   do
   while (TRUE);
It works for me.....
Triple check your connections
I initially added two lines:
setup_comparator(NC_NC);
Because some compiler versions leave these incorrectly setup.
However, once it was working, removed these, and it kept on working.
sl001
PostPosted: Sat Aug 06, 2011 8:27 pm     Reply with quote
Thank you for your efforts Ttelmah,
I had been using the small ccs 12f683 dev board that uses a 14 pin ICD chip. I wonder if these have an external interrupt pin on GP2 as their 8 pin cousins? I built a small test circuit using the 8 pin chip and as you say the Interrupt fires.
Thanks again.
