ELCouz
| [OT] Advice for RS485 |
Posted: Wed Aug 03, 2011 11:04 am |
Off-topic i know but lot of knowledge around this domain.
I'm currently trying to interface my Mini6410 (ARM) running on Windows CE.
The problem is that i need a RTS signal to drive the rs485 chip ( DE and RE pin) and TTL serial ports on the device have only TX and RX...
Or in another way to see the problem a have a device which only have RX and TX lines with no possibilities to output additional signal to drive DE and RE pins...
On the other side, my slaves the pics have no problems to be interfaced with the rs485 chip since they have many configurable I/O pins beside RX and TX pins!!
What would you do with this problem? _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
SherpaDoug
Posted: Wed Aug 03, 2011 1:08 pm |
A common way to deal with this is to have the Start bit trigger a non-retriggerable one shot that times out in the latter part of the Stop bit. _________________ The search for better is endless. Instead simply find very good and get the job done. |
ELCouz
Posted: Wed Aug 03, 2011 1:19 pm |
| Quote: | | A common way to deal with this is to have the Start bit trigger a non-retriggerable one shot that times out in the latter part of the Stop bit. |
That look a little bit complicated (library for comport on windows ce are simple and send only ASCII chars, no configuration beside baudrate) ...
one thing i though is to make the whole thing full duplex using 4 wires instead of 2...
Make one chip always TX and the other always RX.
Or another way maybe a little bit overkill is to relay the TX RX from arm device then process it through a small pic to the rs485 chip...
Don't be shy if you have more ideas
thank you very much! _________________ Regards,
Laurent
ELCouz
Posted: Wed Aug 03, 2011 1:25 pm |
one thing i'm afraid is the way rs485 communicate between chips.. i'm stuck with a ASCII send/receive device for now... i think it require binary mode or something looks like it need a 9-bit communication for the addressing right?
I need to read more on that...
Thanks! _________________ Regards,
Laurent
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Thu Aug 04, 2011 5:12 am |
| ELCouz wrote: | one thing i'm afraid is the way rs485 communicate between chips.. i'm stuck with a ASCII send/receive device for now... i think it require binary mode or something looks like it need a 9-bit communication for the addressing right?
Only if you want addressing. But you can also design packets that contain source/dest addresses if on a multi-drop bus.
I just did an RS485 project using binary.
You just have to think about things a little differently.
