Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
GPS based RTCC
Post new topic   Reply to topic    CCS Forum Index -> Code Library
Jannie Hamman
GPS based RTCC
PostPosted: Thu Jul 28, 2011 3:08 am     Reply with quote
Attached herewith code for GPS based RTCC. Hope you enjoy...
   PIC Garmin GPS 25LVS - 18F4520
      with local time zone correction
      BR set to 9600bps and not standard 4800bps
      Should work with any GPS module
      (c)2008 All rights reserved by Jannie Hamman
   20/9/2008   -  V1.0  -  Original base program
   22/7/2011   -  V1.1  -  Added days of the week calculation
                           Tested with UBlox module - see comment
#include <18F4520.h>
#device adc=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#use i2c(master,fast,sda=PIN_C4,scl=PIN_C3)
#include "stdlib.h"
#priority rda
//Varaiables for GPS
long len;         //Ring buffer length
int i;            //Token counter
char chin;        //RS232 received character
char istr[300];   //Received string in buffer
char tstr[100];   //Test/temp string for string functions
char lon[15];     //Final lon
char lat[15];     //Final lat
char lond[5];     //Long's hemisphere
char latd[5];     //Lat's hemispere
char deg[10];     //Coarse over ground
char time[10];    //UTC time
char date[12];    //UTC date
char ele[10];     //Elevation above sea level
char knots[10];   //Speed over ground
char stats[5];    //GPS status
char cmd0[20];    //Used temp for strtok function
char *index;      //ditto
char toks[]=",";  //, token for strtok
char dowstr[15];  //Day of week
float kmph;       // km/h=knots*1.852
char tmp[3];      //Temp string for atoi ect.
int hr;           //Time hour
int nn;           //Time minutes
int ss;           //Time seconds
int yy;           //Date year
int mm;           //Date month
int dd;           //Date day
int dow;          //Date day of week 0=Sun .. 6=Sat
int maxdd;        //Maksimum days for given month
int xx[]={0,3,2,5,0,3,5,1,4,6,2,4}; //Table for calculating dow
int16 flags;            //Some flags used
#bit incmd  =  flags.0
#bit lfcr   =  flags.1
#bit gotit  =  flags.2
//Get date and time to local format
//Only positive offset implemented!
//Modify for negative timezones
void tmdtlocal(){
   tmp[0]=time[0];
   tmp[1]=time[1];
   tmp[2]=0;
   hr=atoi(tmp);
   tmp[0]=time[2];
   tmp[1]=time[3];
   tmp[2]=0;
   nn=atoi(tmp);
   tmp[0]=time[4];
   tmp[1]=time[5];
   tmp[2]=0;
   ss=atoi(tmp);
   tmp[0]=date[0];
   tmp[1]=date[1];
   tmp[2]=0;
   dd=atoi(tmp);
   tmp[0]=date[2];
   tmp[1]=date[3];
   tmp[2]=0;
   mm=atoi(tmp);
   tmp[0]=date[4];
   tmp[1]=date[5];
   tmp[2]=0;
   yy=atoi(tmp);
   hr+=2;         //Add local timezone for South Africa
   if(hr>23){
      hr-=24;
      dd++;       //Add 1 day
      maxdd=0;    //Check if new month
      switch (mm){
         case 1:  maxdd=31;   break;
         case 2:  maxdd=28;   break;
         case 3:  maxdd=31;   break;
         case 4:  maxdd=30;   break;
         case 5:  maxdd=31;   break;
         case 6:  maxdd=30;   break;
         case 7:  maxdd=31;   break;
         case 8:  maxdd=31;   break;
         case 9:  maxdd=30;   break;
         case 10: maxdd=31;   break;
         case 11: maxdd=30;   break;
         case 12: maxdd=31;   break;
         default: maxdd=0;    break;      //For Murthy!!!
      if(((yy%4)==0)&&(mm==2))maxdd=29;   //Leapyear Feb 29 days
      if(dd>maxdd){  //1st day of next month
         dd=1;
         mm++;
      if(mm>12){     //if December, increment year
         mm=1;
         yy++;
   //Get time in string format hh:nn:ss
      time[0]=(hr/10)+0x30;
      time[1]=(hr%10)+0x30;
      time[2]=':';
      time[3]=(nn/10)+0x30;
      time[4]=(nn%10)+0x30;
      time[5]=':';
      time[6]=(ss/10)+0x30;
      time[7]=(ss%10)+0x30;
      time[8]=0;
      //Get date in string format 20yy/mm/dd
      date[0]='2';
      date[1]='0';
      date[2]=(yy/10)+0x30;
      date[3]=(yy%10)+0x30;
      date[4]='/';
      date[5]=(mm/10)+0x30;
      date[6]=(mm%10)+0x30;
      date[7]='/';
      date[8]=(dd/10)+0x30;
      date[9]=(dd%10)+0x30;
      date[10]=0;
   //Get the day of the week
   yy-=mm<3;
   dow=(yy+yy/4-yy/100+yy/400+xx[mm-1]+dd)%7;
   switch (dow){
      case 0:  strcpy(dowstr,"Sunday");      break;
      case 1:  strcpy(dowstr,"Monday");      break;
      case 2:  strcpy(dowstr,"Tuesday");     break;
      case 3:  strcpy(dowstr,"Wednesday");   break;
      case 4:  strcpy(dowstr,"Thursday");    break;
      case 5:  strcpy(dowstr,"Friday");      break;
      case 6:  strcpy(dowstr,"Saturday");    break;
      default: strcpy(dowstr,"Unknown day"); break;   //Not possible, but you never know!
//Clear the buffer
void clr_buf(){
   long i;
   len=0;
   for(i=0;i<=299;i++)istr[i]='\0';
   lfcr=false;
   enable_interrupts(int_rda);
//RS RDA interrupt ring buffer
#int_RDA
void rsint(){
      chin=getc();
   if(!incmd){
      if((chin=='\r')||(chin=='\n')){chin='*';lfcr=true;}
      if((chin>=' ')&&(chin<='~')){
         istr[len]=toupper(chin);
         len++;
      if(len>299){len=0;lfcr=true;istr[299]=0;}
#int_RTCC
void  RTCC_isr(void)
#int_TIMER1
void  TIMER1_isr(void)
#int_TIMER2
void  TIMER2_isr(void)
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_8);
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16); //1sec
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);   //262mS
   setup_timer_2(T2_DIV_BY_16,31,2);         //1mS
   setup_vref(FALSE);
   enable_interrupts(INT_RTCC);
   enable_interrupts(INT_EXT);
   setup_oscillator(OSC_NORMAL);
   clr_buf();
   rs232_errors=0;
   flags=0;
   printf("$PGRMO,0,2\r\n");        //All NMEA sentences off
   printf("$PGRMO,GPRMC,1\r\n");    //RMC activated
   printf("$PGRMO,GPGGA,1\r\n");    //GGA activated - have elevation
while(true){
//Wait for gps response messages
   if(lfcr){
      delay_ms(200);       //Wait for all messages
      incmd=true;          //Do not receive anymore messages
      istr[len+1]='\0';    //Terminate received string with null character
   disable_interrupts(int_rda);
      strcpy(tstr,"$GPRMC");
      index=strstr(istr,tstr);
      if(index!=0)
            strcpy(tstr,index);
            i=0;
            index=strtok(tstr,toks);
            strcpy(cmd0,index);
            while(index!=NULL){
               i++;
               index=strtok(NULL,toks);
               if(i==1)strcpy(time,index);
               if(i==2)strcpy(stats,index);
               if(i==3)strcpy(lat,index);
               if(i==4)strcpy(latd,index);
               if(i==5)strcpy(lon,index);
               if(i==6)strcpy(lond,index);
               if(i==7)strcpy(knots,index);
               if(i==8)strcpy(deg,index);
               if(i==9)strcpy(date,index);
         strcpy(tstr,"A");
         if(strcmp(stats,tstr)==0)gotit=true;
            else gotit=false;
         kmph=atof(knots)*1.852;
         tmdtlocal();
      strcpy(tstr,"$GPGGA");
      if(index!=0)
            strcpy(tstr,index);
            i=0;
            strcpy(cmd0,index);
            while(index!=NULL){
               i++;
               if(i==9)strcpy(ele,index);
      incmd=false;
      clr_buf();
   }   //if lfcr
//Do the output thing
   if(gotit){
   //***Here everthing is ready and current
   //***I've used an LCD here, but you can do whatever you want!
   else{
   //***Here GPS is still scanning for satellites
   //***My GPS module have a RTC, so that is the only thing that is current
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
