watchdog "autostart"
cerr
PostPosted: Wed Jun 29, 2011 1:57 pm     Reply with quote
Hi There,
I wanna use the watchdog timer on a pic18f86k22.
I have following fuses:
#fuses WDT1024,WDT_SW
which requires me to manually start the timer by calling
setup_wdt(WDT_ON);
in my code. How can autostart the watchdog with out the need to explicitly start it?
Thanks,
Ron
kender
Re: watchdog "autostart"
PostPosted: Wed Jun 29, 2011 6:11 pm     Reply with quote
Ron, are you concerned that your program will get stuck (which would require a reset by watchdog) before it gets to setup_wdt(WDT_ON) ?
- Nick
Read the label, before opening a can of worms.
cerr
PostPosted: Wed Jun 29, 2011 10:35 pm     Reply with quote
- Nick
Yep, what e.g if #use rs232 doesn't initialize properly?
PostPosted: Thu Jun 30, 2011 2:17 am     Reply with quote
OK.
First, #use RS232, only writes to registers, doesn't poll or check anything, so really cannot fail. So it is not really a problem.
However you can enable the watchdog in the fuses.
There are a series of basic 'modes' for the 86K watchdog:
1) No watchdog (NOWDT).
2) Watchdog disabled in sleep (WDT_NOSLEEP)
3) Watchdog controlled by software (WDT_SW)
4) Watchdog enabled by the hardware (WDT)
These correspond to the low two bits in the config2h register.
So if you compile with (say):
#fuses WDT1024,WDT
The watchdog is enabled straight away.
You can test this by checking the bit pattern put into config2h, at the end of the listing file.
So, with this setting, word 2, is given as 1F7E, while with WDT_SW selected, it changes to 1E7E.
Caveat though. Don't use #ZERO_RAM... This takes a long time, and if the watchdog is enabled during boot up, you may well find the chip will never actually boot!....
cerr
PostPosted: Thu Jun 30, 2011 9:35 am     Reply with quote
Ttelmah wrote:
OK.
#fuses WDT1024,WDT
Thanks buddy!
This worked out nicely! Great, that probably saved my long weekend! Smile I didnt' find that anywhere in the documentation... Sad
It wouldn't make sense to call #ZERO_RAM and WDT together anyways, would it? #ZERO_RAM would turn it off again and you have to start it manually by calling setup_wdt(), or am I understanding #ZERO_RAM wrongly?
Thanks,
Ron
cerr
PostPosted: Thu Jun 30, 2011 10:11 am     Reply with quote
Oh Also,
I just realized that I can't turn the WDT off anymore with
setup_wdt(WDT_OFF);
which is a problem. I need the possibility to turn off the WDT while waiting for user input e.g. or while sleeping...
Please advise!
Thank you!
PostPosted: Thu Jun 30, 2011 3:20 pm     Reply with quote
You can't. Read the data sheet.
If enabled by the hardware fuse, the software bit is ignored. You can only control it with software, if you use the software enable mode.
