Better way to return 16 bits?
RLScott
PostPosted: Fri Jun 17, 2011 8:45 am     Reply with quote
Is there any better way to do this in a 18F part (PCH compiler):
unsigned int16 ReadEEdata16(int addr)
   EEADR = addr;
   EECON1.EEPGD = 0;
   EECON1.CFGS = 0;
   EECON1.RD = 1;
   _RETURN_ = EEDATA;      //..low byte..
   EEADR++;
   EECON1.RD = 1;   //..read high byte..
#byte ReturnHighByte = _RETURN_+1
   ReturnHighByte = EEDATA;   //..high byte
This compiles very efficiently, but I don't like having to mess with the compiler's internal _RETURN_ register, in case future implementations of the PCH compiler handle 16-bit returns with different symbols. I tried various ways of forming expressions like:
return (((unsigned int16)EEDATA)<<8)+k;
where k was saved in an earlier step, but they all compiled with many more machine instructions.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
RLScott
Re: Better way to return 16 bits?
PostPosted: Mon Jun 27, 2011 5:31 am     Reply with quote
Well, since on one has any comments on this question, perhaps I could revise the question a little. What are the precautions, if any, of using the _RETURN_ and _RETURN_+1 compiler pseudo registers to form a 16-bit return value, as opposed to doing a normal C-language "return"? I know that the compiler gives a warning that my function is not void and does not return a value (because it does not see that I have done the equivalent thing by setting _RETURN_ and _RETURN_+1 explicitly). But beyond that, is there any risk in writing code this way? For example, is the compiler likely to change in a way that invalidates my use of this symbol?
Robert Scott
jeremiah
PostPosted: Mon Jun 27, 2011 6:59 am     Reply with quote
Did you try the make16() function/macro? It is usually pretty efficient in most of my programs.
PostPosted: Mon Jun 27, 2011 11:26 am     Reply with quote
I didn't respond because you didn't provide the PIC or the #byte and #bit
statements. If you had provided a small compilable program it would
have been easy to drop it in MPLAB and look at it.
RLScott
PostPosted: Mon Jun 27, 2011 7:30 pm     Reply with quote
Ah, yes, that was a lot better than the various expressions I had tried. And even though it is just a tiny bit less efficient than my _RETURN_ method, I think I am going to go with your suggestion just because it avoids that "no return value" warning and is not open to compiler changes regarding the _RETURN_ symbol. For the record, here are both of them. (The part is a 18F2553, and the SFRs are the normal ones dealing with access to the EE data.)
                   unsigned int16 ReadEEdata16_myWay(unsigned int addr)
  0296    C0A5     MOVFF 0xa5, 0xfa9              EEADR = addr;
  029A    9EA6     BCF 0xfa6, 0x7, ACCESS         EECON1.EEPGD = 0;
  029C    9CA6     BCF 0xfa6, 0x6, ACCESS         EECON1.CFGS = 0;
  029E    80A6     BSF 0xfa6, 0, ACCESS           EECON1.RD = 1;
   02A0    CFA8     MOVFF 0xfa8, 0x1              _RETURN_ = EEDATA;
  02A4    2AA9     INCF 0xfa9, F, ACCESS          EEADR++;
  02A6    80A6     BSF 0xfa6, 0, ACCESS           EECON1.RD = 1;
  02A8    CFA8     MOVFF 0xfa8, 0x2              ReturnHighByte = EEDATA;
  02AC    0012     RETURN 0
                   unsigned int16 ReadEEdata16_make16Way(unsigned int addr)
                      int k;
  02AE    C0A5     MOVFF 0xa5, 0xfa9       EEADR = addr;
  02B2    9EA6     BCF 0xfa6, 0x7, ACCESS  EECON1.EEPGD = 0;
  02B4    9CA6     BCF 0xfa6, 0x6, ACCESS  EECON1.CFGS = 0;
  02B6    80A6     BSF 0xfa6, 0, ACCESS    EECON1.RD = 1;
  02B8    CFA8     MOVFF 0xfa8, 0xa6       k = EEDATA;
  02BC    2AA9     INCF 0xfa9, F, ACCESS   EEADR++
  02BE    80A6     BSF 0xfa6, 0, ACCESS    EECON1.RD = 1;
  02C0    CFA8     MOVFF 0xfa8, 0x3        return make16(EEDATA, k);
  02C4    C0A6     MOVFF 0xa6, 0x1
  02C8    CFA8     MOVFF 0xfa8, 0x2
  02CC    0012     RETURN 0
Robert Scott
