foxOnTheRun
| Execution time: how to check length of code block |
Posted: Sun Jun 26, 2011 9:39 am |
I'm looking for a way to measure the code execution time inside the PIC, I'd like to see on the field how much does it take for some routine/procedure to execute, so I can quickly spot slow procedures and inefficient programming blocks.
I'm doing this because I have a timer interrupt, and I need to be sure the code in the main is fully executed and is "idle" waiting for the timer to overflow.
| Code: | timer starts
potentially
slow
code
// wait time
while(flag==1) // sync point, wait for timer interrupt to enable the flag |
I'd like to quantify the "wait time" over here.
_ PIC16F690
_ Internal 8Mhz clock
_ setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
_ set_timer1(65435)
So, overflow events should be 1 every 50us (100*0.5us, correct? - 4 clock cycles for instruction rule).
I started trying to lower/raise pins of the PIC and attaching a LED (naive).. but it's no use, cause the timer is obviously too fast to spot :\
I tried to count instruction following a possible branch of execution.. again, no use, the program is changing path too often, let alone complex instruction (floats).
Any suggestion?
Tnx.
P.S. I don't have a scope :( _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
SherpaDoug
Posted: Sun Jun 26, 2011 11:30 am |
I would set a pin when the "potentially slow code" is done, and clear the pin when the timing cycle ends. Put a scope on the pin and if the pulse width of this signal gets too narrow you are running out of excess time in your loop. _________________ The search for better is endless. Instead simply find very good and get the job done. |
foxOnTheRun
Posted: Sun Jun 26, 2011 1:10 pm |
| SherpaDoug wrote: | | I would set a pin when the "potentially slow code" is done, and clear the pin when the timing cycle ends. Put a scope on the pin and if the pulse width of this signal gets too narrow you are running out of excess time in your loop. |
YES! the code is already there (the LED one).
but.. I don't have a scope (wrote before in the final "P.S."), it's just a home project.
Maybe, I could do something with pickit2 and its digital signal probe mode, I'll look what kind of resolution is up to. _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
Posted: Sun Jun 26, 2011 1:23 pm |
| An alternative is to run the code in the MPLAB simulator. Using the Stopwatch function of the Simulator you can measure the execution time and number of instruction cycles. |
foxOnTheRun
Posted: Fri Jul 01, 2011 3:06 am |
These are all useful info, but I was looking at something implementable "on the field".
I'm trying now to raise and lower a PIN during the wait period to analyze, then externally I've attached a capacitor where I can measure the voltage across it.
It's not perfect, but I have a rough measure of the wait time (given I know the frequency, given the period I'm analyzing is the ON/OFF period of a pwm signal, and given the cycle is periodic). _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
foxOnTheRun
Posted: Fri Jul 01, 2011 5:22 am |
UPDATE
:lol:
In the CCS common asked question guide section there's just the right answer!
How much time do math operations take?
20 mhz PIC16
int8 11.1 [us]
int16 47.2 [us]
int32 132 [us]
float 178 [us]
int8 23.2 [us]
int16 70.8 [us]
int32 239.2 [us]
float 330 [us] _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
foxOnTheRun
Posted: Sat Jul 02, 2011 3:47 pm |
Update:
To get the execution time of some instruction, I've resorted to this way:
| Code: | enable_interrupts(int_TIMER1);
leap=0;
set_timer1(0);
// Code to analyze
lcd_gotoxy(1,1);
printf(lcd_putc,"%Lu", (val_volt()*30)/61);
// ends here
v1=get_timer1();
disable_interrupts(int_TIMER1);
printf(lcd_putc,"\f%Lu, %u", v1,leap); |
If timer1 overflows, it just increments leap; TIMER1 is set as divide_by_1. So, basically, I'm making the PIC displays the increments made by timer1 - with a 8MHz clock, I get 0.5us resolution, nice, practical and effective :)
(can you confirm to be correct too?) _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
foxOnTheRun
Posted: Tue Jul 05, 2011 6:36 am |
Updates.
I'm "somewhat" mapping the execution time of the PIC, result pretty much match the timings given in the guide section.
I was quite satisfied by just 445 [us] to execute int32 += int32*int32, but still didn't understood why my program wasn't functioning properly.. (there's 100ms window interrupt that launch a series of operations).
.. until I forgot that, besides requested operations, there was the timer_0 generating a software pwm :( - a pretty tight one, 10kHz!
Enabled the timer_0 also in the test program, and BANG! the previous operation just jumped to 6246 [us] :|
Let alone printf operations to the 16x2 LCD... (from 3.34[ms] to 280[ms]..). _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
Posted: Tue Jul 05, 2011 7:21 am |
The operation didn't change at all. It is just that an interrupt at 10KHz, means 10000*interrupt overhead (typically 60 instructions), so 600000 instructions per second being executed before _anything_ else is done. Either in the interrupt _or_ the main....
Seriously, look again at how this code is done. Could you use the INT_GLOBAL approach (EX_GLINT.C), or have this as the only high_priority interrupt, and again do your own register saving for the minimum number of registers, or do the job using another dedicated PIC (something silly like a 12F675, just generating this signal)?. Savings here will affect your whole functionality.....
foxOnTheRun
Posted: Wed Jul 06, 2011 6:59 am |
Yes, you are perfectly right, instructions have to be executed by something/somewhere, they do not come up from thin air.
I was thinking at some solutions, lowering the software pwm, demux the native integrated pwm (or mux, I never get the word right) or as you suggested, have another small PIC (or a TLC5940 - just to name something) to indipendently generate a PWM for me.
Working on :) _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
foxOnTheRun
Posted: Thu Jul 07, 2011 3:50 am |
Updates (I'm updating with the intent that this topic could be usefull for other reader in the future):
I have found what was slowing down everything:
| Code: | | printf(lcd_putc,"%3.2wV", val_v); |
This was taking more than 55ms to execute :\
I substituted it with:
| Code: | | printf(lcd_putc,"%3Lu0mV", val_v); |
And this is taking circa 5ms to execute :)
The result is the same, expecially regarding the PIC adc which has a resolution/sensitivity of 4mV (5/2014), so it would have been useless to try to compute mV digit - visually it looks good too. _________________ Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia. |
